Question about Fedders Q Chassis A6Q10F2A Air Conditioner
Fedders won't turn on
Touch pad will not respond will not turn on. power supply good 124 volts
  • jenn fisher May 15, 2013
    i have the same problem, changed the fuse, still wont turn on but beeps when plugged in
  • 4 Answers
You probably blew the fuse behind the control panel. remove the front cover and then remove the control panel (usually a few screws). There should be a glass fuse attached to the circuit board. If its blown then just replace it and you're good to go.
Posted on May 07, 2010
Panasonic th-42pc77u.plasma tv the two fuses on power supply what should voltage be on both.fuses test good .but one fuse has 1 volt.the other fuse house current 124 volts
If you wish to get some detail About Flat panel Television repair ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | Panasonic Televison & Video
The touch pad on my 990 legacy remote does not work?
The touch pad does not respond
Claudia, dismantle and try to clean or just replace with a good universal remote.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 25, 2016 | Televison & Video
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
Dec 22, 2012 | Samsung PN58A550S Plasma TV
My husquavarna lily stitches are too big and won't respond to touch pad
it sounds like the machine needs to be serviced, you have to check
with a sewing machine shop in your area & call them to ask the
price for checking or servicing a sewing machine
Aug 04, 2012 | Husqvarna Sewing Machines
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fedders window ac was running control lights started going on and off ac went on and off then quit power supply is fine. reset does no good
assuming that you have a reset button on the power cord and after pushing the button you dont hear a beeping sound, there's the possibility that your cord is defective. Check it with a volt metter at the end of the terminals.
Sep 23, 2009 | Fedders A6Q10F2B Q Chassis Room Air...
Power supply suddenly 'dead'
You check the power supply using multimeter. but before everything make sure the you are getting power from the power outlet.
Here is how you can check the power supply with multimeter
If the wall outlet and the power cord are good, make sure the connection at the motherboard is secure. Then you may have to face the fact that the power supply itself is bad. If you have a multimeter, you can test the power supply output before purchasing a new one. Simply follow these steps:
  1. Turn off the PC, but do not unplug it. Open the system unit. Set the multimeter to read DC volts in the next range higher than 12 volts. Locate a power connector similar to the hard drive (or CD-ROM drive connector that is unused) and turn on the PC.
  2. You can also unplug a drive connector and use it. Turn on the PC and insert the BLACK probe into the power connector on one of the BLACK wires. Touch the RED probe to the YELLOW wire on the power connector.
  3. The multimeter reading should be +12 volts. Now touch the RED probe to the RED wire and the reading should be +5 volts. If no readings or different readings occurred, you’ll have to replace the power supply. If the readings were correct, you should check the P8 or P9 connectors at the motherboard. These connectors may also be named P4 and P5. To check these connectors, perform the following:
    • Insert the BLACK probe into P8 at one of the BLACK wires. Insert the RED probe into the P8 connector at the RED wire. The reading on the multimeter should be +5 volts.
    • Check the power going to the motherboard connections by inserting the RED probe into P8 at the YELLOW wire and you should get +12 volts. Leave the BLACK wire touching the BLACK wire at the P8 connector. Check the BLUE wire and the reading should be a -12 volts.
    • Now move the BLACK probe to the BLACK wire on the P9 connector. Test the WHITE wire by inserting the RED probe and the reading should be -5 volts. Check the RED wires on the P9 connector and you should get +5 volts on each red wire. You won’t get exactly 5 or 12 volts, but the readings will be very close, such as 5.02 volts.
    • If the Power Supply is a couple of volts off in either direction, such as when the RED wire should be reading -5 volts but it reads -8 volts, or if there are no readings, replace the power supply.
Mar 22, 2009 | Computers & Internet
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Fedders Q Chassis A6Q10F2A Air Conditioner Logo
605 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
