When I add water to the bottom (top of the filter) I can not get water to drop down into the chamber and can not make coffee. It looks clean. What is the little valve on the side for?
How long does it take for the water to reach the top of the tank? Also, the sales clerk sold me...
(More)
How long does it take for the water to reach the top of the tank? Also, the sales clerk sold me some number 1 filters. I wasn't sure if I where to put them or if she sold me something that I didn't need for the Biolette Mocha Express.
My bialetti coffee maker ends up boiling the coffee if left on the stove. Is it meant to do this?...
(More)
My bialetti coffee maker ends up boiling the coffee if left on the stove. Is it meant to do this? Should the valve not release the pressure?
When I first got my Bialetti Mukka, it would leak from the sides. Online, I found the fix of...
(More)
When I first got my Bialetti Mukka, it would leak from the sides. Online, I found the fix of soaking the O-ring in hot water before using. I was using Peets ground coffee and it worked fine for months.
Now, I switched coffees (one fine grind Nero, one medium ground Fresh n Easy), and water comes out clear. However, if I turn it off for a while when water first steams through, then turn it back on, it comes out with coffee. Anyone have this problem or know a fix? I've tried tampering with temperature, high, low, still same problem.
Thanks!
The pressure valve on my Bialetti 6-cup Moka espresso coffee maker blew out after 1 month. I have...
(More)
The pressure valve on my Bialetti 6-cup Moka espresso coffee maker blew out after 1 month. I have had another unit for nearly 30 years (it still uses the same replacement gasket and basket as the new one), and the pressure valve is still intact on that one. I did not subject the new unit to more heat than the older one. 1) Can I re-set the valve (there were no instructions in the box) 2) If not, where can I get a replacement valve. 3) Why do you think the pressure valve blew out when the older one has never blown out?
