I have a lexmark printer x5495 and i installed it in my computer just now and received a test page but now when i try to print on line it says it is printing but nothing comes out
  • 8 more comments
  • gerrybrite Aug 17, 2008
    please note i cant get the job to cancel even though i go in and try to cancel it - i set up
    and when i printed a test page it worked fine
    but when i print or try to print off the internet or work pad it wont print- it says printing but nothing comes out -on the copier part it works fine plus i have not set up the fax part of the machine could that be the problem and -could i have the hook up to computer in wrong slot?
    it says ready
    how do i uninstall the printer drive and do i put the disk back in after i uninstall it
    this is brand new i just bought it
    i am on windows vista is that the same because i am not finding my computer
    please note there is not add/remove program
    just an add program no remove program and is there a possiblity it is listed under another program -instead of add/remove
    i tried what you said and i got an error message the lexmark x5400 series is currently in use please wait until the printer has finished printing and then uninstall
    why if i just installed this printer with the disk it came with would it not work-
    should i reinstall the disk again
    ok so i turned off the computer and turn it back on and it printed all the pages but since i deleted all the printers that means i have to reinstall the disk again right -and what message do i wait for to see if it is running correctly
    now it is saying printer not installed
    i just started printing this page you guys gave me the information on and then i went to an email
    and started printing that - but it still says i have one document pending so i think somehow the cancelation mode did not work but i am able to print now i hope it keeps up -thanks people
    Sergeant:
    Champion:
  • 298 Answers
Go to control panel and then devise manager find printers click it se where it says your printer right click , update driver , let it search the internet. and then install driver that should work for you.
Posted on Aug 17, 2008
  • 594 Answers
Make sure your printer is plugged in to the right connection on the computer. if it is and turned on a alert bubble should come up says found new hardware. when that comes up click on it so you can finish the installation. you will need to put the disk back into you drive. than once the install hardeware comes up you will need to push this time only and next. than next again it should be on the recommended option for cd drive. once that is done the computer will search for the drivers needed to complete the installation off your disk. once complete you may need to restart the computer. than once restarted try to print off the wordpad and see if it solved the problem.
please do not forget to rate and comment about your experience today.
    Sergeant:
    Champion:
  • 221 Answers
Try running your Printer on a PC with any other OS (other than Vista) and if it works, visit Lexmark Website and Download any Patch(es), if available for Vista, else contact Lexmark Customer Care.
Sahaja Yoga is the Only Gateway to the Kingdom of God and is the Culmination of all the Religions and Spiritual Traditions of World.
Goto www.sahajayoga.org to attain your Self Realization and find a Sahaja Yoga Center to goto.
Sahaja Yoga is the Only Way to Save the World and is Free of Charge.
  • Dr. NITIN  KHANDELWAL
    Dr. NITIN KHANDELWAL Aug 17, 2008
    Didn't the Solution I provided help you?
  • 4,472 Answers
Go to control panel> printers and faxes, and delete the printer.
Go to lexmark.com search your printer model and you can downloaded the latest software for your OS. make sure in printers and faxes that the printer you have installed is the default printer with the check mark. I will be happy to assist you further so please don't reject my help.
Thanks,
Lee
  • Lee A.
    Lee A. Aug 17, 2008
    I hope that you will reconsider and accept and rate my solution accordingly and appropriately.
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 17, 2008
    Also just for future information why I recommend downloading the software/drivers off the website is because most times it will be newer then what comes on the installation disk and also is a sure way to make sure the disk is not the culprit.
    Thanks,
    Lee
    Genius:
  • 1,689 Answers
To get the printer uninstalled:
click start, then go to all programs, look for your printer utility and you will see an uninstall option.
you may also run the CD that came with the printer, let it initial and Lexmark install wizard will provide you options if you want to remove, reinstall or repair the currently installed printer.
but if you did not run the CD in your computer (since it is vista and has preloaded drivers):
go to "Control Panel", then click "Printers" right click ont he printer icon then "delete". you will have to confirm the command and your computer will select another printer icon as the default printer. after this you may now get it reinstalled, using the Lexmark Vista drivers, and not the drivers that was provided by vista.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:26:0:0
hope this helps...
  • 4 more comments
  • marlon john madrid
    marlon john madrid Aug 17, 2008
    on your vistas control panel make sure it is in classic view, then look for "programs and features" if that is what you are looking for.
    please check my first post too if in case
    just restart he computer and it will loose the printing status on your taskbar, then you may uninstall the device from your computer.
    it will, we are just making sure that your printer will use lexmark drivers not the vista drivers for your printer.
    well generally after installing the printer it will confirm that it is online and ready (on control panel > Printers). once it does you may now be able to print again from your lexmark.
    if the printer is already on printers and faxes, right click on it, "run as administrator" then set the printer online.
    ouch, well anywho thanks for using fixya. :)
  • 928 Answers
You can go to the add/remove programs then select the printer software then click on remove The driver will be removed as well. Or you can go via programs then select the printer then select uninstall. AFter that shut down the computer and printer. turn it back on and run the CD again.
  • 4 more comments
  • Thomas Lim
    Thomas Lim Aug 17, 2008
    Oh you can go to control panel then to programs and features. Select Classic view
  • Thomas Lim
    It would be best if you uninstall via the programs list instead. Make sure as well that the driver that you use is the one for Vista. To be able to be sure you can download the file from the link below
    Links
  • Thomas Lim
    You have to highlight the program you want to remove before you will see the remove option
  • Thomas Lim
    Shut down the computer then turn off the printer. Turn it back on and purge all your print jobs then do the uninstall.
  • Thomas Lim
    Installing it again would just inform you that it is already installed. It will not fix the problem at hand
  • Thomas Lim
    Just that it is Online and you are able to print then your good to go
    Master:
  • 623 Answers
Go to my computer
right click properties
hardware
device manager
printer
action
scan for hardware changes
  • 1,800 Answers
This is the best solution u just uninstall ur printer driver and install this one because i dont knw what is ur OS so i let u pick up the right one.
the original driver and software.
after the installation rebbot the system and see what u got
100% problem gone
rate me!!
  • 2 more comments
  • Jalal Sordo
    Jalal Sordo Aug 17, 2008
    and this is ur user manual and instructions this might help u to fix the problem
    http://www.lexmark.com/publications/pdfs...
    this the driver link
    http://www.downloaddelivery.com/download...
    if this is not helping u tell me and i will give another solution!!
    rate me fixe you!!
  • Jalal Sordo
    and this is the best what i got for u just read and follow sir; and apply what u ve read!!
    Printing a Web page
    You can use the Toolbar to create a printer-friendly version of any Web page.
    Load paper.
    Open a Web page using Microsoft Internet Explorer 5.5 or later.
    If you want to check or change your print settings:
    a
    From the toolbar area, click Lexmark 􀂌 Page Setup.
    b
    Adjust the print settings.
    c
    Click OK.
    Note:
    For additional print setting options, see “Using Print Properties” on page 38.
    If you want to view the Web page before printing:
    a
    Click Preview.
    b
    Use the toolbar options to scroll between pages, zoom in or out, or select whether to print text and images
    or text only.
    c
    Click:
    • Print
    or
    • Close
    , and continue to step 5.
    5
    If needed, select a print option from the Toolbar:
    • Normal
    • Quick
    • Black and White
    • Text Only
    Printing photos or images from a Web page
    Load paper. For best results, use photo or heavyweight matte paper, with the glossy or printable side facing you.
    (If you are not sure which side is the printable side, see the instructions that came with the paper.)
    Open a Web page with Microsoft Internet Explorer 5.5 or later.
    On the Toolbar, the number of photos valid for printing appears next to Photos.
    If no number appears next to Photos:
    a
    From the Lexmark logo drop-down menu, select Options.
    b
    Select the Advanced tab.
    c
    Select a lower minimum photo size.
    d
    Click OK.
    The number of photos valid for printing appears next to Photos.
    Click Photos.
    The Fast Pics dialog appears.
    5
    If you want to print all the photos or images using the same settings, select the size you want, the blank paper
    size in the printer, and the number of copies.
    6
    If you want to print one photo or image at a time:
    a
    Click the photos or images you do not want to print to deselect them.
    b
    To make common editing changes:
    Right click the photo or image.
    Click Edit.
    Make your selections.
    Follow the instructions on the screen.
    5
    When you are finished making changes, click Done.
    6
    Select the size you want, the blank paper size in the printer, and the number of copies.
    7
    Click Print Now.
  • Jalal Sordo
    its easy click in my computer
    control panel
    printers and ...
    remove the printers icone
    and itall it again and carry on with steps that i gave u^^
  • Jalal Sordo
    try the task manager and kill the proccessus that made by the priner then u will be able to uninstall it
  • 13,433 Answers
Open up the printers and faxes. start -> control panel -> printers (and faxes) it may also be start -> printers and faxes
see the status of your printer, is it online / Ready? or offline?
  • 6,487 Answers
Try first to turn off the power of the printer and the computer for about 5 minutes then try to print again , if still not printing cancel all the print jobs and try to print again...
Hope that helps........
  • 3 more comments
  • Mark Gil
    Mark Gil Aug 17, 2008
    If that's the case try to check if the printer is set as the default printer and its staus is online, under printer and faxes on control panel...
  • Mark Gil
    Restart the computer and try to uninstall it again....
  • Mark Gil
    Yes I agree with voodoomox because Vista has a capability to install software to devices like printer , so to make sure your using the software from the setup Cd better run it first then just follow the step by step procedure..
  • Mark Gil
    Since it still printed all the pending print jobs try first to print a new document and see if it will wokr, because if it work printer is already working and only needs to be restarted...
  • Mark Gil
    Ok just run the setup CD and it will tell you what to do and when it say do a test print and print out a test print its already working fine......
My Lexmark X125 has been disinstalled by accident I think. I cannot find an installation disc. My computer does not recognize it. Frankly, I think I picked the wrong button when I was trying to reboot...
GO TO THE LEXMARK SITE ,,THEVE GOT THE DRIVERS FOR ALL THE PRINTERS AND STUFF ON THERE,,, GET THE DRIVER THEN CONNECT THE LEXMARK,,GOODLUCK
Oct 05, 2008 | Televison & Video
I am trying to install a lexmark 640 series printer to my new compaq laptop with windows vista. I installed the printer using the installing **** that came with and it says it was successfully installed...
Have you tried going thru the control panel, printers and faxes and selecting ( with the right mouse button) that printer and then properties... to print a test page? or.. have you used the device manager to check that the printer is working properly? To use the device manager, right mouse button MY COMPUTER then selct the Hardware tab and then Device Manager.. You may find your printer listed under Imaging Devices.. Right mouse that and select Properties.. You wil have some options there to update the drivers too.. Hope these tips get you going...
Good Luck..
Sep 28, 2008 | Televison & Video
Lexmark printer problem
make sure your comp has selected it as default fax.
Sep 19, 2008 | Televison & Video
HP Photosmart C7200. Printer is not printing the bottom quarter of the page, despite print preview showing the whole page fits within the margins. I am using A4 paper
Try reseting the printer to factory defaults- also does the same problem happen when you a printing from a computer or trying to print a scan directly on the printer?
try restoring the printer to factory default settings, you can also try reinstalling the drivers on your computer.
Aug 05, 2008 | Televison & Video
I HAVE A LEMARK 1290 AND IT WILL NOT COMMUNICATE WITH MY COMPUTER I HAVE TRIED REINSTALLATION, DIFFERENT PORTS, AND HUBS MY COMPUTER HAVE 4 PORT SLOTS AT THE BACK I HAVE TRIED ALL OF THEM AND NOTHING WORKS
I had a similar problem with Lexmark 3500 - 4500 series. I found that when Norton was disabled, the document printed. After soem further dicking around, I figures if you configure firewall setting to low, then docs print OK. Give it a whirl & see how you get on....worked for me. (I do think Lexmark are **** though.....!!!!)
Sep 15, 2008 | Televison & Video
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
Electro Med Services...
