Question about Rancilio Silvia Espresso Machine
Espresso sprays and sputters
When I make espresso with Silvia, she sputters and sprays the espresso. Am I using too fine a grind? Thanks. AB
  • ModGirl Aug 21, 2008
    Thanks, Andy. I've been using Illy ground espresso, which I figured would be a "just right" grind. I had some success switching to the smaller liner for the portafilter. I had been using the one for a double shot, and I switched to the single.
  • Anonymous Jan 05, 2009
    same problem
You might also try running half a cup of hot water through it before you put the portafilter on - usually does the trick.
Posted on Oct 22, 2008
How long does it take to fill the cup?
Sounds more like too coarsely ground espresso to me. Should take about 25 seconds for 30 ml of espresso to come out ... that is normally more like a 'trickle'. If yours comes much faster, you might try grinding it finer and/or tamping more firmly.
Best regards,
Andy
Posted on Aug 18, 2008
Why won't my portafilter stay engaged once the water starts dripping? It flies off and sprays coffee grounds, and this started last week. Stays in place only if I wrestle with the filter handle.
It is possible that the grind you are using is too fine and causing so much back pressure that the portafilter is moving, also possible that the group gasket installed need to be replaced, I have also seen this happen with damaged screens.
Jul 27, 2015 | Rancilio SILVIA EXPRESSO MACHINE Silvia...
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
When I try to make an espresso shot, it runs out very fast and watery.
The coffee needs to be ground finer and tamped harder.
I grind my own coffee. I have never found any supplier that grinds their coffee fine enough.
Dec 28, 2010 | Rancilio Silvia Espresso Machine
I've tried grinds from a very fine to a coarser grind in my Rancilio Silvia, but the water is going through the portafilter/coffee too quickly. When I clean out the portafilter, there is too much dry...
Check the shower screen to make sure it is not damaged. Then try this get coffee ground from the store at #2, 3, 4 and 5 at least 1/4 pound each then use that to figure out what setting works best for your machine, also note the tamping pressure. Fill portafilter to rim then tamp to fill ring in basket.
Aug 24, 2010 | Rancilio Silvia Espresso Machine
The machine it is new and coffee it comes out very quckly and has not body at all I dont know it I should to give back the espresso or it is what I can disolve myself?Any advice? please, thank you
Agreed.... you need a high quality burr grinder for a high quality espresso machine. Then put it on Fine grind and adjust the grind up or down from there until the espresso comes out with a slow smooth flow. Also be sure to tamp the grinds with a tamper so it is evenly compressed!
May 20, 2010 | Rancilio Silvia Espresso Machine
Diminished pressure when brewing espresso
try adjust grinder,try go litlle bit courser ,check screen it need to be clean.
Aug 22, 2009 | Rancilio Silvia Espresso Machine
Have a Rancilio silvia machine, grind coffee with a Rancilio rocky. Problem is that sometimes... more often than not, the coffee coming out of the portafiller spouts comes out quickly and sprays all over...
Try taking the portafilter out and run water through it as if you were making an espresso. check if the water coming out is very fast. I believe there is a screen there that is held in by a flat screw. If you take that off you should be able to see light through it. If you can't soak it in some cleaner until you can see light through it. There could be a couple of things causing this. The other thing that comes to mind is that the boiler has to much pressure but it should say on your gauge if that is happening. You might find that it just needs a good cleaning.
Mar 21, 2009 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso water flows too quickly about 7 seconds
  1. check the coffe filter>> it could be teard up and leaking(check it carefuly it is hard to see sometimes)
  2. check the pressure you get from group. 7 - 9 bar pressure you should get to handle. if it is biger than check by pas valve and adjust the pressure, also check up boiler security valve(security valve for water for coffee)
Feb 09, 2009 | Rancilio Silvia Espresso Machine
Coffee not strong enough
I had a problem like this with my first proper Gaggia. Cutting a long story short I found that the coffee I was using wasn't ground finely enough. The Illy stuff that comes in cans was ok, but pretty much everything else preground (incuding Lavazza!) was too coarse.
Sidestep the problem by getting yourslef a Rancilio Rocky grinder then you can adjust the grind in TINY increments for your perfect coffee moment...
Sep 24, 2008 | Rancilio Silvia Espresso Machine
Rancilio Silvia Espresso Machine Logo
333 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
