Question about Gateway Computers & Internet
Windows vista keeps refreshing - Gateway Computers & Internet
Http://www.download.com/SUPERAntiSpyware-Free-Edition/3000-8022_4-10706568.html?tag=lst-3-10
Posted on Sep 17, 2008
Gateway dx4380g-uw308 keeps restarting?
Windows 8 has a neat utility that is called "Refresh Your PC". This process does not change any of your files (documents, pics, vids, music, etc.). If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, refreshing your PC will restore Windows 8. You'll need to upgrade to Windows 8.1 after the refresh has finished.
To refresh your PC
  1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
  2. Tap or click Update and recovery, and then tap or click Recovery.
  3. Under Refresh your PC without affecting your files, tap or click Get started.
  4. Follow the instructions on the screen.
Aug 20, 2014 | Gateway DX4380G-UW308 Small Form Factor...
HOW TO FIX LG FLATRON 1750HQ OUT OF RANGE WITH WINDOWS XP?HOW TO START THE MONITOR ON A WINDOWS XP IT WORKS ON VISTA HOWEVER ON XP WINDOWS IT SAYS OUT OF RANGE WHAT ARE THE CORRECT SETTINGS FOR WINDOWS XP...
your refresh rate is set too high. boot into safe mode set to 640 x 480 then reboot. once it is up try adjusting the refresh rate to around 60 or lower. or buy a newer monitor.
May 20, 2014 | LG Flatron 563LE 15.1" LCD Monitor
Monitor won't connect to cpu
OK,Hello. The screen resolution (probably the refresh rate also) is set higher then what your new monitor is designed for. boot your computer and hold down the F8 key this should bring up the Advanced Boot Options window. you will see a list . select Enable Low Resolution......using the up and down arrows -press enter or enter key. This usually works well for windows 7 and Vista. Now If Windows starts to your desktop you can now set your resolution and refresh rate properly- set the refresh rate at 60 Hz. Window should give you a Recommended Screen resolution rate. go ahead and use it. Good Luck
Feb 10, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
I have a Compaq Presario sr111onx desktop with Windows 7 Pro OS 32 bit and it is slow will it be better to use Windows xp?
It depends on the Experience Rating Index that Win 7 gives you. To see the rating, right click on My Computer and select Properties. If it asks to refresh the rating index, do so. After that, check which one has the lowest rating. If it's the processor that gets the lowest rating (if it is below 2) then yes, you should install Windows XP. If it is the graphic card, or the RAM memory that has the lowest rating, you can upgrade them to make it run better and keep Windows 7.
You can see more about the rating scores on this Microsoft website: http://windows.microsoft.com/en-US/windows-vista/Windows-Experience-Index-Understand-and-improve-your-computers-performance-in-Windows-Vista
Jan 25, 2011 | Compaq Computers & Internet
Input Not Support
This means, that your operating system is not set to the recommended resolution of your monitor. Your monitor has a "fixed" resolution where the image will look best. You can change the solution in Windows XP if you right-click on a free space of your desktop, then choose "Properties". In the new window, that comes up, select the rightmost tab. There you can use the slider to adjust your resolution. Just try some different resolutions until the message disappears. If you use Windows Vista oder Windows 7 you can access the resolution windows by right-cliking on your desktop and selecting "Screen resolution".
Jul 18, 2010 | AOC 19LVWK LCD Monitor
I have a Mag Innovision 2200W Monitor. I messed with the settings, and now I get a ''mode not supported'' error. The computer is running in the background, and works with other monitors, but not this one....
Hi
To resolve this issue connect a monitor which is working with the Computer. Now right click on desktop and select properties(if windows XP) or personalize/screen resolution (if windows vista / 7)-> Now click on settings tab (windows XP) or change the resolution of your monitor-> Choose a lower resolution rate maybe 800X600. Now try connecting the other monitor with your Computer and it will work.
If not then check for the refresh rate of your monitor, adjust it to 60 Hz. You can adjust refresh rate from settings tab->advanced button(in XP). Screen resolution/Display settings(under windows 7/vista)->Advanced setting->monitor tab ->refresh rate.
This will surely resolve your issue.
Daniel Scott
Jun 08, 2010 | Computers & Internet
Microsoft vista service pack 1 - screen and displays have altered
that's the problem of resolution or ur monitor refresh rate.... set ur monitor on 1024X678 resolution with 60gzh refresh rate...
Mar 03, 2009 | Microsoft Windows Vista Home Premium with...
My mp3 player won't sync
Reformat the player, and reload the songs.
Dec 16, 2008 | Audio Players & Recorders
Internet
  1. Look at the network connection icon wheter its blinking or not during refreshing the web page.
  2. If it does not blink check connection between router and pc
  3. check Netgear internet settings.
  4. Check if there is any block settings in the router.
Window Vista has lots of updates, and it's bit defender is working everyday to check your pc. This is really slowing your programs including Internet Explorer.
To test if your Windows is haveing problems or not, you might download a linux live CD such as PClinuxOS or Knoppix to test the connection.
If you can browse the internet no problem then it would be your Windows has a problem.
Mar 20, 2008 | Computers & Internet
Windows vista!!! wont work
Vista is your problem You will have to go to the Ilo web site for vista drivers- if there is not one then yup your name fits.
Jul 31, 2007 | iLO (2 GB) MP3 Player
Computers & Internet Logo
298 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
