Question about Palm TX Handheld
Expansion card I want to save on the expansion card. How is this done?
  • 2,794 Answers
Use the Palm Quick Install and select the memory expansion card. It will put it into the card at the next sync.
Posted on Aug 21, 2008
Where is the expansion valve?
Next to the blower motor,in a box,the freon has to be removed to replace expansion valve,took my Nissan truck to Midas to have one installed.Here's a link to a new one. Expansion Valve at AutoZone com Best Expansion Valve Parts for Cars Trucks... Here's another link,find the cooling unit,it's in their. SAVE 20 GET 10 GIFT CARD ON ONLINE SHIP TO HOME ORDERS OF 100 OR MORE
Sep 17, 2015 | 1997 Nissan Sentra
How do you use the expansion slot?
I'm going to assume you're talking about the backside of the desktop computer? If so, you'd have to take the cover off of it to expose the guts. There is a big flat circuit board inside. This is called the "motherboard" or "mainboard".
If you look at the expansion slot from the inside you'll see the same metal plate covering it. This is to prevent dust from entering the system, and enhance cooling by controlling airflow. The plate can be removed from the inside, but I don't recommend it unless you're adding an expansion card to that slot.
Now, if you'll look at the motherboard right by that metal plate, you'll see a "slot". There are many different styles, based on the age of your computer, but in any case, it is where you might plug in an expansion card of some kind. Nowadays, just about every new machine has everything built into the motherboard, so there's not a lot of expansion to be done. But you may want to add a better graphics card, a second Network Interface Card, or something. That's what the slot is for. If I'm understanding your question, that is.
Dec 11, 2013 | E-Machines eMachines Desktop PC
Can I add a SATA controller in a PCI slot? if so what is the storage limit? I am looking to have atleast 4TB.
Yes this can be done and the only limit on size is the drive size. The current max size for mainstream drives is around 2TB so make sure the adapter will host more then one SATA ports as at least 2 drives will be required.
Also make sure the adapter card will work with the Operating System as many are designed to be used under Windows only so if you are running Linux or BSD, there may be no support.
The other limit is the fact that the PCI is not a fast bus by current computer technology standards. If there are additional PCI devices such as network interface cards, integrated graphics, modems, soundcards, game controller adapters, USB expansion ports, Firewire expansion ports, etc.. theses devices will all be sharing the bandwidth of the PCI bus, leading to slow read and write performance of the additional storage.
If you are adding these drives to have fast storage, I suggest saving the money for a new system that makes use of current technology.
Dec 15, 2009 | IBM eserver xSeries 205 8480
Wot is the memory card slot for
HI,
The memory slot is an expansion slot that you can put a camera card (SD card) into so you save all you photo's to that instead of the internal memory.
This is because your camera only has a limited amount of internal memory limiting you to the amount of pictures you can save on the camera.
Purchasing a memory (SD card) is certainly an advantage and they can be used in card readers, MP3 players and computers etc.
Regards.
Sep 14, 2009 | IT Works Cameras
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Mikomi webcam
Hey, I had similar problems, but luckily found a solution to this problem and any future installation problems I may have, lol...click on the link below, download (when given the option to run/ save/ cancel, choose save). Its really good. All I had to do (after download) was plug in my hardware and it done a quick scan, found what i needed and downloaded it for me!
http://driver-pro.com/related/english/driver-scan/?gclid=CLjaosCaqZUCFQpYQgod7ld-jw&sofs=4&hit=1&adurl=12004
Dec 07, 2007 | Micom (VIP-4004-ISO-DX) (VIP4004ISODX)...
Can't run applications from an expansion card
In some cases, applications developed before Palm OS® 4.0 that are loaded to an expansion card may encounter errors when launched. However, these applications generally run properly when installed directly to your handheld's internal memory. Here's how to do that: 1. Access the Applications launcher. 2. Open the Menus. 3. From the App menu, select Copy. 4. In the Copy To: pulldown menu at the top of the screen, select your expansion card. 5. In the list of applications, locate the file you want to copy to your handheld's internal memory. Highlight the file. 6. At the bottom of the screen, select Copy. Then select Done. 7. Go back to the Applications launcher. At the top right of the screen, there's a pulldown menu with different application categories. Choose All (this is a category that's on your handheld, not on your expansion card). 8. Locate the application you copied, and launch it from this screen. 9. Contact the developer of the application for more information on application compatibility with expansion cards.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Expansion card doesn't stay in.
Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
Expansion card content is not backed up during HotSync process.
Through the use of an SD or MMC expansion card reader, which connects to your desktop computer, you can copy the contents of your expansion card to your hard drive. Where can you get an SD card reader? Try your local electronics or computer store, or look online.
Palm TX Handheld Logo
32 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
