Question about BenQ PB6100 Multimedia Projector
Pb6100 Did you ever find out the problem for your blank white screen on your pb6100? I have the same issue and would like to know what others have done before trying to hunt down a new motherboard. Thanks in advance, SM
I think the problem has to do with the videochip component. Perhaps it went misconfigures and need to be flashed. Iwouldn't know how to do this, though.
In any case the problem has nothing to do with your motherboard, because this symthom points to internal problems rather than PC gear hardware.
Posted on Aug 27, 2008
Hp 650 blank white screen
You may want to check using an external monitor.
The DV6000 series unit have problems with Video GPUs processors. If you have experienced any other kind of issues like the WiFi not working ect. you may have a bad GPU.
Try re-seating the GPU with heat gun ( View on Utube )
Hope this helps
Apr 09, 2014 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
I keep getting a white blank screen on my Acer Aspire 4315. Sometimes on boot-up, other times while in the middle of a task. It is running Vista and has only 1GB of memory so I've ordered 2GB. Not sure...
A blank white screen generally indicates a video problem on a laptop. This can be a bad lcd data cable, a bad video driver, or an overheating/disconnecting video chip.
Oct 11, 2011 | Acer Aspire 4315 Notebook
HTC P3400i display is not working,blank white screen is visible. incoming call is OK. What can be done on this? What is the cost of new Display to upgrade?
Oct 18, 2010 | Cell Phones
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
WHITE BLANK SCREEN
Hi My name is Vortash .. may i suggest that for the price you would pay for a new card you could get a new projector off Ebay or Amazon that just needed a bulb at a fraction of the cost .. regards Vortash
Feb 22, 2009 | BenQ PB6100 Multimedia Projector
Hi. I have a problem with a white line on the screen
Hi
This will probably be a vertical white line you are seeing ?
Common BenQ Mainboard problem that can unfortunately only be solved by replacing it.
Nov 26, 2008 | BenQ (200NSH-LAMP) Projector Lamp for...
Blue screen
Hi Guys,
I recently struck this issue with one of our PB6100's. To resolve I did the following:
  1. Enter service menu (found on AVForums): PRESS AND HOLD UP BUTTON UNTIL LAMP HOURS ARE DISPLAYED, PRESS THE POWER AND BLANK BUTTONS TOGETHER
  2. Under the Fan menu select "More Options". You should then be in the "Fac7 Submenu".
  3. Select "Hard Reset". Note that this will reset the lamp hours also!
  4. Power off & then on again. Test input.
The above worked for me. Hope it helps.
Jun 20, 2008 | BenQ PB6100 Multimedia Projector
It just shows a blank white screen when I turn it on
Hi beans88
This is unfortunately a faulty Mainboard that will either have to be repaired or replaced.
The Part Number of this board is : 55.J8601.001 and if you decide to rather replace than repair it , you could expect to pay in the region of $125 for this part.
Thanks for using Fixya and good luck.
May 20, 2008 | BenQ PB6100 Multimedia Projector
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
Locked in 'search' mode
I don't know if its a common issue for pb6100, but i have the same problem. I am resorting to take apart the projector to see if i can 'reset' it.
Dec 18, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
156 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
