Question about Garden
The vacuum part of my Aquabot Junior Industrial Z does not work. It still moves in the pool, but their is no suction. Please help
SOURCE: Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
Posted on Jun 19, 2009
  • 83 Answers
SOURCE: Aquabot is pushing out water but will not move to clean the pool
I am not sure if this is the manual that you are looking for, or not, but just in case. If you following the link below it will take to you the T2 User's Guide, with the trouble shooting.
http://www.i-love-my-aquabot-automatic-pool-cleaner.com/support-files/aquabot-turbo-t2-manual.pdf
According to the trouble shooting guide:
Pumps Water, but Does Not Move or Moves Slowly
1. Remove any foreign matter that may be obstructing Drive Tracks.
2. Check Drive Belts and Tracks. Make sure they have not slipped out of place and that they're not loose.
3. Observe Drive Pulley, if it is not moving contact Customer Service.
Posted on Jul 09, 2009
  • 15 Answers
SOURCE: Aquabot Turbo T won't climb
1.`. Replace your old, water logged floats. They will dry out when the unit is out of the pool, and the unit will work fine until they water log again, which may takes as few as 10 minutes in the pool. 2. Stop using all those words *********** didn't teach you and probably didn't even know...This is a common problem. http://www.i-love-my-aquabot-automatic-pool-cleaner.com/ gives some really good insight, too! S. Christian dansker01@msn.com.
Posted on Aug 22, 2009
  • 333 Answers
SOURCE: My Hayward pump works fine until I hook up my Dirt
I have the same problem.I have to fill the entire hose with water in order for it to start working
Posted on May 19, 2010
tweedleedee0
  • 15 Answers
SOURCE: my resently purchased Dirt Devil pool cleaner
Sometimes u have to use the return water that enters your pool to fill up the hose with water u use to get all the air out of it, its kinda like priming it. or u can submerge the hose all the way. And if that still doesn't work then sometimes giggling the hose might get it to start suction
Posted on Jun 27, 2010
My aquabot only stays in a small area of the deep end even if you move it manually it goes back to the same place, what can be done to solve this problem?
this may or may not help, sorry in advance. on the hayward series of robotic cleaners, this sometimes happens. it is from lack of water flow or reduced flow. clean the filters and if there is a restrictor plate, remove it. that will give more suction and allow it to climb better.
also, you might adjust the return jet direction to provide a circular path in the pool
Aug 09, 2017 | Aquabot Pool & Spa
Pool rover junior won't back up
Try this: Take the Rover out of the pool and lay it down, wheels down. With your garden hose, shoot a strong jet of water into the impeller opening, alternating sides, 3-4 times each side. There's probably some material stuck in there.
May 30, 2014 | Aquabot Pool Rover Above Ground Robotic...
Dirt devil pool vacuum wont move
If one of these pool cleaners is not working, you likely have an obstruction in the flapper. That would explain why you have suction and no movement. With the pump off, turn the cleaner upside down and check for any twigs, rocks, etc. in the flapper. If you don't see anything or see something you can't reach with your fingers, remove the base plate with a flat head screw driver and check there. The base plate is where the waste is collected.
Jul 09, 2010 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
Aquabot wont pump or move, intermmittent
Well either you have a jammed up motor, or a bad motor, or the Controller unit has faulted.
http://www.robotshop.ca/PDF/aquabot-turbo-t2-manual.pdf
Above is a manual, this should help you it has exploded diagrams to help. There seem to be many ways that it could get tangled up, or maybe the belt has come off, any way it's about time to A: Get a screwdriver, or B: Call a service man....
Jun 01, 2010 | Aquabot Aquaproducts Automatic Swimming...
My aqua bot will not move
Check and make sure that there is no debis in the drive belts! If you are near Phoenix AZ I my be able to look at it with you. Also, the website http://www.i-love-my-aquabot-automatic-pool-cleaner.com/Aquabot-Troubleshooting.html may be useful to look at S, Christian dansker01@msn.com
Jul 20, 2009 | Aquabot Robotic Pool Cleaner
Jul 05, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
May 11, 2009 | Aquabot Turbo T
Aquabot T2 moving in circle
The T2 has one set of belts and a single drive motor. Since one side must be rotating to be moving in a circle, we can then assume that the motor and belts are not the issue here. The two halves of the brushes are connected by a mechanism that allows them to turn independently of the other half. They can rotate about 3 times before they “lock” and act as it were one (not split) brush. This “slippage” is how the cleaner turns. Make sure that they do lock by manually rotating one side. If not, you will need new brush/wheel tubes.
A parts diagram can be found here:
Aquabot Parts and Repair
Jan 09, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Garden Logo
93 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
