Question about Philips FWC550 Shelf System
Power shuts off
I have a Phillips FWC550 Shelf Unit that will immediately go to EcoPower mode after I turn it on. This happened after I plugged about 6 speakers and a sub-woofer into it. It all worked until I turned the volume way up and it just shut off. Any help would be appreciated.
  • Anonymous Oct 04, 2008
    same problem, i want to fix it myself. how do i do that. dont care ab the warranty
  • Anonymous May 04, 2009
    same here, i knew i shouldnt have hooked up a subwoofer where the speaker was supposed to go
  • 4,234 Answers
The unit is in "protect" mode. Basically a problem is detected in the last output stage of the amplifier section and the unit shuts down to prevent further damage. I suspect that you connected too many speakers to the system. The impedence load was too low for the amp section to handle and one or more output transistors have failed. This should be a straightforward repair for any local repair shop. Figure on $20-$40 for parts plus the local labor rate for the repair. I am not familiar with your specific model, but these shelf units are all similar in design. I will try to locate the service manual for this one to get you more details.
Dan
Posted on Aug 19, 2008
My Philips FWC550 automatically keeps switching to a radio station and has volume issues!
You have a bad Rotary Encoder or Display Microprocessor(computer inside your Philips). If you are interested in having it repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jun 20, 2015 | Philips FWC550 Shelf System
Need user manual to operate fwC550 system
What country are you in? You may be getting the local Philips support page. I found a tri-lingual (English, French and Spanish) manual for the FWC550 here: http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=FWC550&hlt=Link_UserManuals&mid=Link_UserManuals&scy=US&slg=AEN . The direct link to that manual is http://download.p4c.philips.com/files/f/fwc550/fwc550_dfu_aen.pdf . This copy has some pages duplicated with unreadable pages followed by better scans of the same page. Thus the English section is from page 1 - 58.
I hope this helps.
Oct 18, 2014 | Audio Players & Recorders
Need manual for philips model fwc550/3701
Hello
Get into this link. You can download the user manual to your device. OK.
www.usersmanualguide.com/philips/home_audio-video.../fwc550
Jan 16, 2012 | Audio Players & Recorders
How do i turn off the demo mode?
The "DEMO" mode initializes when power is initiated in the unit for the first time.You cancel it by turning turning the power on by using the button the unit or the remote.If you unplug the unit from the power outlet between uses, and plug it in again...it will go back to the demo mode.this can be avoided by leaving the unit plugged in between uses and/or install 3 AA batteries in the battery compartment in the lower rear behind the main battery compartment .these batteries are memory storage.it is not necessary to instal the 9 size D batteries for portable use unless you use it as a portable...I hope this was helpful...
May 18, 2010 | JVC PC-XC70 Shelf System
When you turn on the unit nothin happens but when you shut it off you can use the radio an other options
when the earphones are plug in the unit you can hear the music cd radio etc . the problem is when i take the head phones out of the unit you dont hear nothing please help.
Nov 22, 2009 | Sony LBT-ZX6 Shelf System
The protect mode issue
Disconnect and/or turn off speakers and see what happens.Check for running cooling fan and that unit is clean inside and has good ventilation.
Sep 07, 2009 | JVC HX-C6 Shelf System
How to diable demo mode on mx-kb30
Turn the stereo on, wait two minutes for the demo to start running then press the "demo/cancel" button located under the "sound mode" selector.
Mar 10, 2009 | JVC MX-KB30 CD Shelf System
Power problems
The set is detecting a problem internally and shutting down to prevent further damage. This is often call protection mode. I would guess that there is either a bad connection somewhere or a part starting to fail. If there is a pattern to the failures, a quick trip to the repair shop is in order armed with that info. Rough guess would be abaout $30 in parts plus the local labor rate. This is based upon my own repair experience with these systems.
Dan
Mar 26, 2008 | Sony MHC-GX450 CD Shelf System
Loses power after (10 seconds) then shuts off
Sounds like a bad capacitor in power supply.
Jan 05, 2008 | Philips FWC550 Shelf System
Philips FWC550 Shelf System Logo
415 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
