Question about Ovens
The oven element stays on and gets overheated
  • 24 Answers
You need a new thermostat This is not something you can do yourself it should be done by a qualified person
Posted on May 30, 2011
Top Oven overheating already replaced sensor.
have an electrician check the element wiring as it should only get red when on full heat but then be controlled by the thermostat
it appears that the element is bypassed the thermostat or the thermostat is failed
for the bottom not to get red is a further indication of incorrect wiring of the elements
Nov 16, 2015 | Maytag MEW5630DDB Oven
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
Oven is overheating
If it has an electronic control there could be a welded contact on one of the oven relays causing the element to stay energized. A rare thing could be a shorted element that is getting a ground current bypassing the control but this usually will stay on even when the oven is off.
Feb 10, 2014 | Kenmore Ovens
I have a whirlpool accubake duo, super capacity 465 and when I try to bake something the oven wont stay on...how do I get the oven to stay on
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
Mar 01, 2011 | Whirlpool Ovens
NEFF U1271 Oven overheating
Hi it could well be the thermosat has stopped working
Jan 24, 2010 | Neff U1721 Double circotherm Electric Oven
Frigidaire FEB27T5D Electric Dbl Oven oven does not get hot
replace the upper oven calrod element it is an easy job just unplug the range turn the range around remove the back plate loosen the element wires from the element remove the element from the front any parts supply will have your replacment part such as www.applianceparts.com
Apr 26, 2009 | Frigidaire FEB27T5D Electric Double Oven
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Oven light
This is done to regulate the temperature. Higher heat settings will let the element stay on longer, while lower settings will turn it off sooner. Even on high, the elements may turn off periodically because there is a switch called a temperature limiter. Its job is to keep the element from overheating.
Aug 11, 2008 | Dacor MCS130 Millennia Electric Single...
Oven heating element stays on
If element stays on even with oven turned off you probably have a bad main board. A relay on board is probably stuck on. If it stays on, but at a reduced heat...not getting red hot, it may be from a shorted wire causing 110 volts to get to element.
Nov 02, 2007 | GE Profile JTP18 Electric Single Oven
Electric oven too hot
difficult to see what you have done here! can you come back with some info: do you have an earth trip fitted in your consumer unit? how many wires are fitted to the element? did you touch any other wiring except those connected to the element?
Apr 16, 2007 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
