Question about IBM ThinkPad T60 Notebook
I need to change my ip adress. - IBM ThinkPad T60 Notebook
    Master:
  • 340 Answers
You can search some software to change it fast. Or you can change it by your self: First change the Physical address, you can see the address attribute of the network card, and change it to any character string by 0-F.( If you can't find where: my PC attribute--> hardware -->Device manager-->then find the network card to see its attribute, you will find there is a options of the XXX address). Then, change the LAN address to another one After that, restore your computer.
Posted on May 30, 2011
Can i just swap my new pc for my old one and still recieve e mails or will my adress change
IP address will change but that should not influence email pickup which is subject to installed email reader software.
May 17, 2012 | HP Computers & Internet
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
I want to modify ip adresse
Use notepad to write the following:
{IP;2,192,168,001,201'}
{IP;3,000,000,000,000'}
{IP;4,255,255,255,000'}
{IS;1,09100'}
{XJ;Termine'}
and print it to your printer
These will change your
IP adress
Gateway
your submask
activate and deactivate the port with an adress at 9100
and at the end display Termin?
respectiveley
Jul 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
Describe your epson c900 wont print Problem will not print my files are waiting in the list but not printing out
Clear all the prints from that list and try again.If it is not printing check the machines ip adress and the ip adress that on the driver.it could be that it was changing the ip adress @ power on.
Oct 19, 2010 | Epson AcuLaser C900 Printer
How to configure zebra plt2844 on netware or do you know the default ip adress
go to the driver and print the configuration label, if you see the ip adress, just write the IP adress on the browser and you be abel to check the configuration from the printer, it is possible to change some setings from there.
Aug 25, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Need ip address for syrens, not sure if i remember right: 192.168.1.1???
Hi Stephan,
the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
  1. go to control panel > network and sharing/networking >change adapter settings
  2. then you'll see your local area connection
  3. right click on it>properties
  4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
  5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
  7. the dns server ip show should be your router ip adress
  8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
I hope that it will help & don't forget to rate
Kind regards
Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
We have a KM c250 that we use for scan to desktop and occasional faxing. Starting last night we started getting an error when scanning. In the log is says that it is a Forward TX Error. To my knowledge...
hello this can be caused if the scan sends to a wrong IP adress. If the machine that you are sending scans has dynamic IP (dhcp), then the ip can change as you reboot the computer. To solve this, have a fix IP adress in your computer's network preferences, and check if scan sends to this adress
May 29, 2009 | Konica Minolta bizhub C250 All-In-One...
Fixed IP adress problem
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
IBM ThinkPad T60 Notebook Logo
56 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
