Question about E-Machines eMachines Desktop PC
Having problem with operating system disc....can get to advanced bios menu but do not know what to change the priority of.... first 2 items on the menu won't let me change priority value and the 3rd choice is already on cdrom
    Scholar:
  • 79 Answers
For some BIOSes 'enter' key changes the boot priority, other use '+' and '-' keys to change boot priority or PgUp and PgDown to change it. Try all 3 or when you get to advanced settings check the help menu by pressing the correspondent key listed on the lower part of the BIOS screen, most of the time is 'F1' key.
Note: Arrow keys changes drive selection.
Have a nice day.
Posted on May 30, 2011
    Sergeant:
  • 247 Answers
There should be a boot menu command at start up just like you entered the system bios, i believe the e machine boot command is F12 that will give you the opportunity to boot from what ever you want on that boot only. so in your case of course you would scroll down to cd and hit enter. press any key to boot hit any key and boot.
Non system disk or disk error
Hi is the bios detecting the hard drive? Are you able to open the laptop and chek if the hard drive is correctly plugged into mother board
Feb 06, 2013 | HEWLETT-PACKARD 625 Notebook PC
My computer will not boot windows xp os
Do you mean it won't pick the disc? If so, try F10 it should also give you a boot menu if you don't see press any key to boot from cd... The other option is boot into BIOS and change your boot order. CD-ROM/DVD should be the 1st option.8_28_2012_7_14_07_am.jpg
Aug 28, 2012 | IBM ThinkPad X41 Notebook
My dell studio 1555 is not reading cd's except it makes a weird noise and the cd becomes lodged in the drive . after some prying its possible to pull it out
First off, you might need your windows operating system disc. 1. Turn on your laptop 2. Start tapping on F2 once you see the Dell Logo 3. Once your inside BIOS go to Boot options or Boot menu 4. Change the boot priority, make the CD the top priority. 5. Once you're done with step 5, insert the operating system disc into your CD/DVD drive 6. Press F10 (Save and Exit). The laptop will then restart. 7. Check if it will boot from the OS disc, if it does, then there's no problem with your optical drive. If it did not boot from the operating system disc, then there's a big chance that your CD/DVD drive is already broken.
Note : if you're not satisfied with the steps above, you might want to try 2 operating system discs. You don't have to install them on the laptop, we just need to use it to verify if the CD/DVD drive is already broken and needs to be replaced.
With my experience as a technical support, usually this kinds of symptoms(the things that you mentioned) says that the DVD drive is already broken or defective.
Hope this helps!
Sep 12, 2011 | Dell Studio 15 Laptop
Whenever I turn on my laptop the screen is blank with a white dash mark flashing in the top left corner of the screen. What do I do?
That is the signal that the BIOS no longer finds an operating system installed on the hdd. All you are left to do is to reinstall it. Use the recovery disk that came with it.
Jul 05, 2011 | Acer Aspire 6920 Notebook PC
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
I have a gateway 500xl that the previous owner reformatted the harddrive wiping the xp operating system. I've upgraded the ram but without an op system I cannot turn the machine on. I need to install...
Hi there.
For this process you will need:
1) The hard drive you want the operating system on.
2) The operating system disk (Windows, Linux, etc, depending on your os choice)
3) A CD/DVD drive.
Firstly you will need to enter the BIOS on startup by pressing the Delete key repeatedly as your system starts up. In the BIOS you need to locate the boot disk priority section. You need to set priority 1 to your CD/DVD drive and priority 2 to the hard drive you wish to install the operating system to. Once this is done save changes to the BIOS and exit. Your system should now restart and on boot-up it should display a message "Insert bootable disk" or something like that. This is where you put in the operating systems install disk into your CD/DVD drive. Once it is in restart your system. Now your PC should boot up and ask you to press "Enter" to boot form the CD/DVD. Press enter to proceed. The setup should now begin, just follow the steps given by the setup wizard. Once the setup is finished and your PC reboots and on startup you get the same message about pressing "Enter" to begin setup just do nothing. Your PC should then switch automatically to your newly installed operating system and boot into it. Once your PC is fully booted into your operating system of choice remove the setup disk.
Slasher_X
Nov 13, 2010 | Gateway 500XL PC Desktop
My computer won't boot, I just get a black screen that gives me two options, bios menu and something else f2 or F12
iF you cannot resume with the Operating system..try to go to Bios and set up the boot priority 1 = hard disc,
If this wont still work, your Operatiting system might be corrupted.. go to bios again and set up the boot priority 1 = cdrom.. next, try to insert the installation disc of your OS but do not install it, select option: REPAIR only.
If the cdrom would not boot, unplug the battery of the bios, then put it back again correctly. After this, boot again your cd.. Thanks..! dont forget to comment if you like my post.
Aug 24, 2010 | Gateway GT5654 Desktop PC
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
I cant change my booting priority in bios setup
no need to go into the BIOS setup for such simple and easy task, go to start -> right click My computer -> Properties -> Advanced -> Start up and Recovery ->Settings -> now u can choose the default os and time out also u can edit the boot.ini manually by clicking edit
Hope this solves your problem.
Jan 12, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
456 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
