Question about Car Audio & Video
Hi i have and 1999 lumina ltz i recently got robbed for my radio and they ripped my wires so now i have a boss 626ca car radio that needs to be installed.. my problem is that the colors dont match up can you please tell me what colors are what....
    Scholar:
  • 111 Answers
Constant 12V+ - Orange Switched 12V+ - Yellow Ground - Black/White Illumination - Gray/Black Dimmer - Brown/White Antenna Trigger - Pink Left Front (+) - Tan Left Front (-) - Gray Right Front (+) - Light Green Right Front (-) - Dark Green Left Rear (+) - Brown Left Rear (-) - Yellow Right Rear (+) - Dark Blue Right Rear (-) - Light Blue
Posted on May 30, 2011
I need the easiest possible directions to replace the coolant temperature sensor in my 1999 Chevy Lumina ltz 3.8 v6 car please.
The coolant sensor temperature is usually found just beneath the cylinder head, on the engine block.
You just disconnect the 1-2 wires and then undo it with a wrench.
The sensor will look like one of these:
1999 Chevy Lumina ltz 3 8 v6 coolant temperature sensor Google Search
Just be aware .. you may have TWO such sensors on your vehicle.
One sensor (usually with 3-4 electrical pins) is near the thermostat and works in conjunction with other sensors to regulate fuel/air according to engine temperature.
The other type of sensor is in the block near the cylinder head. It sends a signal to the temperature gauge on your dashboard ONLY. If your temp gauge constantly reads too hot or too cold .. this one is the culprit.25939754-r0ibht2u2t2rhetbyfvb2pry-5-0.jpg
If it's a running fault .. speed .. rough running .. fuel. It may look like this:
Nov 03, 2015 | Cars & Trucks
How doi install a radio after the original has been stolen and wires ripped out
You will need to buy an install kit even if they did. The back of new Radio's don't have anything but a plug to connect to. So the install kit will be needed to hookup the four {or just two depending on it's already installed options} speakers, the power, and ground. Plus the Antenna cable. They will all be color coded.
For example:
http://www.modifiedlife.com/1999-geo-metro-car-radio-wiring-diagram/
http://www.commandocaralarms.com/wiring/1995-/Geo/Metro/848.html
Nov 18, 2013 | 1994 Geo Tracker
What is the firing order for a 1999 Chevrolet Lumina LTZ 3800 series ll, v6, 3.8 Liter engine
Here is the firing order for that engine and vehicle, and let me know if you need any help to understand this diagram, or if you require any further assistance.
Oct 03, 2010 | 1999 Chevrolet Lumina
Hi, I am a chilean owner of Chevrolet Lumina LTZ
I've had the same problem. Change the starter solenoid in the steering column because if you don't, eventually it will not start at all. Right now, it is warning you.
Sep 04, 2010 | 1997 Chevrolet Lumina
Don't have radio code for 1998 chevy lumina ltz. How do i get code?
Call the parts depts at your local chevy dealers. With a 12 year old car a nice parts guy will usually give you the code for free. Look up how to pull the radio code up on the internet (you have to hold down certain buttons on different theft-loc radios). Give the numbers to the parts guy and they will call in and get you the unlock code. Otherwise they charge you to get the number...good luck
Jun 06, 2010 | 1998 Chevrolet Lumina
How to change the battery on a 1999 Chevy Lumina LTZ
You will need an extra long extension for your socket wrench. Or you can just stack a few small ones together. You will have to extend your reach from above the battery.
Be careful not to touch the positive post when your socket is on the bolt. Good luck
Apr 04, 2010 | 1999 Chevrolet Lumina
Engine cut out while driving. Would turn over, no start.
If it were mine, I would check to see that there is fuel to the engine and the ignition system is working.
Apr 17, 2009 | 1999 Chevrolet Lumina
1999 Lumina LTZ will not start on the first try
try checking the fuel pump relay or the new pump wasnt put in right or the new pump is defective by not putting enough pressure on the injectors
Mar 26, 2009 | 1999 Chevrolet Lumina
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
