Question about Insignia IS-LCDTV32 32 in. Television
Insignia TV - black and white
I own an insignia TV and one day the AV1 and AV2 connections no longer "work" instead they just produce black and white picture - sound still comes in fine. The cable connection and the PV/PRB/CR works fine also.
Is there a way to fix the AV ports?
    Problem Solver:
  • 8 Answers
I would first try new cables, if not, then the board needs replacement.
Posted on Aug 21, 2008
Cannot find channels when i connect cable directly to tv
Make sure you have the correct input selected from the menu such as AV1 AV2 HDMI1 or 2 and so forth.
Aug 20, 2011 | Insignia NS-L26Q-10A 26 in. LCD TV
Hi there, I am getting some problem in connecting my DVD player to LCD TV on AV2 port. If I connect the same to AV1 port,it works fine but that port is already in use for my set top box so if I want to...
I expect if you look at the menu you will find that AV2 is set up as S-Video or Component etc. etc. Set it up as composite or RGB. The same as AV1.
Jan 20, 2011 | Televison & Video
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
INSIGNIA LCD NOT WORKING
check skart lead connections,and check that the tv is on the right channel,ie av1,av2 ,or skart 1or 2
Jul 30, 2009 | Insignia NS-L26Q-10A 26 in. LCD TV
Sanyo 68cm. AV1 is Black and White. AV2 and normal Tv is OK
the two AV1 and AV2 have different inputs on the IC,
the first port has a disconnection,
take your tv for a check up
Mar 20, 2009 | Sanyo DS13204 TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
INSIGNIA TV FLAT PANEL (not LCD) cant play PS3
Check to make sure it is on either the AV 1 or AV 2 channel
Nov 25, 2008 | Televison & Video
Cannot timer record with Insignia HD TV and LG DVR/VCR
Make sure when you do the process two things: one, a blank tape or If it is a dvd recorder, a blank disk is inserted, in the tape make sure the tab that prevents recording is not broken.Two, before exit the timer recording menu, make sure that there is not a instruction that says "done" or "confirm" or any word meaning that all the steps went through.
Nov 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Vizio VO32L & VO37L - PIP and Composite connection problems.
look in your owner's manual and you will see a list of input that can work with each other and ones that can't. If you don't have your service manual, you can go to vizio.com and get it there.
Jun 21, 2008 | Vizio L37 Television
Only black and white movies
your tv is posibley on svhs instead of av1 or av2
have a look at the logo that comes on when you chose the channel
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Insignia IS-LCDTV32 32 in. Television Logo
454 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
