Question about Acer Computers & Internet
Acer s242hl monitor does not have mounting holes
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: i have the acer AL
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support; http://support.acer-euro.com/drivers/monitor/al1916w.html
Watch out for caps going bad in your monitor also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 23, 2010
How to remove the monitor stand on acer s242hl?
For the S242HL
1. Unscrew the screws from the plastic base and remove this. You are now seeing the metal part of the base.
2. Lay the screen glass down, on a flat surface. If you crouch down and look into the area the metal piece is inserted, you will see a plastic 'tab' that is locking the metal piece in place. Wedge something to lift the plastic tab, so that you can pull the metal piece out. You can use quite some force to lift the plastic and then the metal bit just slides out.
I've just done this so I know it works.
Apr 28, 2014 | Acer Computers & Internet
No power
Look if you can safely get it apart for the fuse inside the unit and if possible test the power cord and where it connects, this is the place to begin---total dead units are usually easy to fix, follow the AC voltage from the wall or voltage source inside to the fuse etc.
Dec 20, 2012 | Acer S242HL bid LCD Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
Rehow could fix the sreen on wall?
Remove the LCD monitor stand, purchase a wall mounting bracket. There are several types, one is on an articulated arm which allows you to left, right, up and down. Another type mounts flat to the wall with limited up and down adjustment.
You need to check the mounting holes on the wall brackets so it matches the mounting screw holes on the LCD screen.
Nov 26, 2010 | LG 22" FLATRON LCD Monitor
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities...
Aug 20, 2010 | Acer AL1916W 19" LCD Monitor
How do i attach a wall mount to the back of my 20" samsung?
Samsung wall mount bracket WMB 1900T adapts for four hole wall mounts. Fits 19" to 22" monitors. Price is $27-$42 at online stores.
Apr 09, 2009 | Samsung T200HD LCD Monitor
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
I want to remove stand 'holder' so I can mount on an Atdec V-AT-DB Dual Focus LCD Desk Mount
I have the same problem and I hate to admit it but I'm on the verge of putting a blade in my hand held router and cutting the plastic away. I don't want to do that since maybe I may need the mount someday, but...
Jun 06, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
381 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
