Question about Sport & Outdoor - Others
Bought a new mini shark 50 by Geason Powersports yesterday. It is suddenly having trouble with the engine shutting down and also restarting. Check fuel, oil, etc. Can't find anything wrong. Any advice on what we could try? Melissa
  • 12 Answers
SOURCE: sudden shut down
You probably have a clog of dust between the fan and the heatsink. It would be best to have it disassembled to clean, although a few models have clean-out doors to the fan on the back. You might be able to somewhat clear it by blowing canned air in the vent, but this may push dust balls into the fan that go right back against the heat sink.
Posted on Jun 18, 2009
Cellular Guy
  • 114 Answers
SOURCE: phone will not stay on. It shuts down, restarts,
This is a KNOWN problem with this phone.
Read all of this answer before deciding what you want to do. You'll have several options:
To correct the problem yourself you'll need to have another (older) phone (not a 7205 Intrigue) that your phone number can temporarly be transferred to. Then, follow these steps:
1. Assign your phone # to a different device using its EIN.
2. Startup the other phone and make sure all text messages & other undelivered stuff is picked up by the other phone.
3. Turn the other phone off, reassign your # to the 7205 Intrigue, and start it up. Problem solved!
Some key points:
- you can do this yourself on Verizon online--if you have another operable device to switch to; otherwise, you can go into a Verizon store and have them switch to a test phone for you. Obviously, the other phone cannot be a 7205 Intrigue.
- after switching your # to this new device, you MUST wait SEVERAL MINUTES and confirm that all the msgs floating around in the system while your Intrigue has been malfunctioning are delivered to the new phone.
If you switch back and forth too quickly the problem will NOT be solved.
Nokia is aware of this problem and sent a bulletin on 7/30 stating that the bug will be addressed in the next software release for this phone (no target date specified.
Intrigue owners will not receive any notification when this software release is available, and that the phone will have to be brough to Verizon to have them load the update.
Unless you're attached to the Intrigue, exchange your phone for a different model and avoid this headache! (That is, of course, if you kept the original packaging which Verizon requires for exchanges of even faulty, nonfunctional equipment.
Call verizon, and see if the software update has been released. a. If so, go have it installed on your phone.
b. If not, do the EIN switch. If the problem happens again, go back to step II.
Posted on Apr 08, 2010
Testimonial: "Thank you! You were right on! As soon as the phone was removed from the network it stopped power cycling."
SOURCE: GE Mini Mouse 98563
Hi, I had the same problem. The USB device has what appears to be a circle with dots connected to it facing the port. The dots are actually the word "Connect" in infintessimally small letters. Plug it in, then use your thumb to press down on the circle while using another finger to press up on the device's underside - in effect, squeeze it between your fingers where the circle is. You'll see a red light blink. At that point you can push the "connect" button on your mouse and it will work.
Posted on Nov 05, 2010
  • 1116 Answers
SOURCE: I have a 2005 lincoln
Throttle actuator control position sensor....it's a small piece that goes in front of the engine.....cost about $110......must have Allen star key to take out if you're going to do it yourself.
Posted on Jun 01, 2011
  • 640 Answers
SOURCE: My Cub Cadet 2130 has
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Posted on Sep 18, 2011
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
2001 v70 t5 wagon. auto all of a sudden dies while driving along. when i try to restart, battery is dead. no indicators or trouble codes are recorded in the system.
First thing would do is check just how securely the battery leads are attached to the battery. Next have a look at the earth strap from engine to car frame connections. A complete cut out as you describe can only occur if there is sudden complete shut down of the electrical system, this would also account for the ECU not recording trouble codes, it needs at least to be on before it can record anything. The next check point would be the main fuse and starter relay and then the starter switch itself; there has to be break/loose connection somewhere in the 'on' circuit. This is not a 'short' otherwise the main fuse would have blown.
Mar 14, 2011 | 2001 Volvo V70
Must wait 30-40 mins to restart engine
Check your manual to see if it call for premium or regular. Premium has less energy per gallon and is designed for higher compression engines. What makes it "premium" is more anti-knock compounds - not better quality or performance. Sounds like a vapor lock problem that resolves as the engine cools. Regular gas may help with that.
May 03, 2010 | Briggs & Stratton 3000 PSI Pressure Washer
1999 Ford Contour..
Have you checked your ignition coil? A bad ignition coil can also cause this.
Aug 13, 2009 | 1998 Oldsmobile Aurora
The engine shut down while on stop and go traffic. Tried to restart but the throttle was weak and shut down again. After shutting everything down for 5 minutes, restarted the engine. The throttle w
If the car is having trouble maintaining idle (the tach dips and car dies) the common causes are the idle control valve and camshaft position sensors. The cam sensors failing will be indicated by a check engine light.
The ICV can removed and cleaned with good results (I think there is a write up on bimmerfest) or purchased new for about $100.
While you are in there check the intake boot that is Y shaped for cracks, it's prone to fail and will mess up your idle too.
read up on the major forums and you'll get more info
May 10, 2009 | 2001 BMW 325
98 Jetta...stopped while driving
During this past winter, I was driving my 98 Jetta GL and it suddenly shut down in the middle of the road. It restarted but would only go a little ways before doing the same thing. I got it checked out and it turns out I had to get new fuses. I knew someone who could put them in it was very cheap to fix.
May 10, 2009 | 1998 Volkswagen Jetta
Sudden shutdown
What you have not indicated is whether it shuts down or restarts. If the laptop restarts then it is possible that the processor is a celeron and there is a problem of a overheating. If you are sure about all software issues be alright, I suppose you get a new fan. At times after a fan has gone weak, regardless of the contacts it has with the processor, it will still not cool; but it also be good to check the processor temperature if its goes over 60 degrees. good luck.
Aug 27, 2007 | Computers & Internet
Sport & Outdoor - Others Logo
42 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
