Question about Toshiba Satellite L505DGS6000 Notebook
I have a L505d-gs6000 the other day it suddenly would not boot , I tried the retart repair and it hangs up.. the start normally just hangs up and loops back to where it says startup repair or start normally , when I try to start in safe mode it hangs up at windows\system32\drivers\atipcie.sys... help
    Scholar:
  • 81 Answers
Your best bet is to do a full system recovery. its looks like your laptop is new enough that it has a recovery partition installed on it and will recover your laptop to factory settings as it just came from the store. at the 1st screen you might have to push either f10 or f12 it will say on your screen which 1 just click on it and it will pretty much run itself
Posted on May 30, 2011
How do I do the factory reset on the Toshiba laptop Satellite L505D-GS6000
press and hold f8 and press power button. hold f8 key till you see the recovery menu. select factory reset.
Mar 04, 2015 | Toshiba Satellite PSLV6U-01F009...
My toshiba pslv6u-01f009 is missing the charging receptacle
Toshiba might be able to advise you regarding that part.
Jun 02, 2014 | Toshiba Satellite L505D-GS6000,...
Toshiba satellite l505 gs6000 amd mobo fried can i replace with the l505 intel board??
if your motherboard is fried and you are running windows it is probably best to find a replacement motherboard of the same make and model so when you go to start it up it should work.
if not you can attempt to have it fit into the laptop but laptop motherboards don't have a standard size so some modifications might need to be made
Jan 06, 2014 | Toshiba Satellite L505D-GS6000,...
Toshiba L505D GS6000 -power up,will not boot or power up can get the utility screen, but black screen again after. What can I do to Fix ?
  • Easily Repair / any PC / Laptop running Windows, all versions. Full suite of Logical Auto repair facilities on one disc for Windows XP ~ Vista ~ 7 ~ 8
  • This is what the Repair Technicians and Engineers use to fix and speed up PCs. Our repair disc comes with lots of programs that will resolve almost all problems with your PC.
  • Boot Up Failure - Slow PC - Blue Screen - Stubborn Virus - Malware Issues can be resolved with this Disc. This Disc does not contain any OPERATING SYSTEMS LIKE WINDOWS & OR VISTA OR XP. This Disc is strictly for Repair only.
  • Tools Included for : - ANTI VIRUS / TROJAN, BACK UP, BIOS / CMOS, BLUE SCREEN, BROWSERS / FILE MANAGERS, HARD DISK WIPERS, DEVICE DRIVERS, EDITORS / VIEWERS, FILE SYSTEM TOOLS, HARD DISK TOOLS, MBR MASTER BOOT RECORDS, MS DOS , NETWORK OPTIMISERS, PARTITION , PASSWORD, PROCESS, RECOVERY, REGISTRY, RESTORE, SECURITY / ENCRYPTION, START UP , SYSTEM INFO, SYSTEM TESTING, TWEAKERS
  • This Disc is specially manufactured and produced by THE SPARE PEOPLE only, so ensure you buy it from THE SPARE PEOPLE SELLER Below only to protect your computer againt fraud Discs which can damage your computer. Please ensure you buy THE SPARE PEOPLE branded Disc onl
Sep 08, 2013 | Toshiba Satellite L505D-GS6000,...
Why is my Toshiba Satellite L505D-GS6000 Wifi driver not found?? After resetting, checking device manager, trying fn+f8, and dowloading the driver it still doesn't show up!!!
Sounds like a bad wireless card or the card slot.I would try replacing the wireless card.When wireless cards go bad they either cause the laptop to not boot,low or no signal reception or the card isn't seen at all by the motherboard or operating system or .both.If it isn't showing in device manager either with a caution sign or installed the card is most likely bad
Mar 08, 2012 | Toshiba Satellite A135-S4727 Notebook
Loss my wireless connection
If you reformatted your hard drive, you'll need to reload the wireless card drivers for the computer. They are not part of Windows.
Feb 23, 2012 | Toshiba Satellite L505D-GS6000,...
Can I connect my LG flat screen tv monitor to my toshiba satellite L505D-GS6000 labtop. There is an HDMI-DVI IN port on the back of tv. On laptop I don't see an HDMI port but there is an RGB (monitor)...
Ok in order to hook up the laptop to the TV you have 2 options
First option.
Buy something like this
http://www.amazon.com/Sewell-Converter-All-One-Cable/dp/B003BVVYSM it will directly interface your laptop with your tv. The benefit will be you will get sound to your tv from the laptop
second option.
you will need a vga to hdmi cable like this one
you can buy this here
now this option will only let you have just the video from your laptop on the television because a VGA cable is a video only cable and port.
I hope this helps you.
Apr 19, 2011 | Toshiba Satellite L505D-GS6000,...
Toshiba satellite l505d
unplug laptop and remove battery. Take out both memory sticks and locate on the motherboard under sticks two points marked with ***. Replace one memory stick, plug ac adapter back up and while jumping the two points at the *** (use paperclip, flathead screwdriver or other metal object to connect the points) power up computer. This, if done properly, will reset bios, removing password.
Jul 21, 2010 | Toshiba Satellite L505D Notebook
Toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Feb 22, 2010 | Toshiba Satellite A60 Notebook
Toshiba Satellite L505DGS6000 Notebook Logo
273 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
