Question about Refrigerators
F15 fault. RF610A F&Paykel fridge. Fridge section not cooling adequately. Freezer section working well. Beeps on opening fridge door. Beeps stop after about 10-15 seconds or if you press a button on the display panel. Help would be appreciated.
  • wilsonsylvia May 30, 2011
    thankyou for your help re the fan. that sounds pretty logical.. shall investigate as it sounds as though I need to find a F&P fridge technician with a new fan to fix it. It seems odd that the error code F15 is not in the manual that comes with the fridge.And they call it a "smart" frig!
    yes
    President:
  • 2,187 Answers
Check the FAN of the unit. IT may have started to go bad (weaken) or have gone bad or some wiring is loose which may cause it to go out.
Posted on May 30, 2011
Our fridge bleeps every time the door is opened and now the freezer is not working
Hi Ruth,
If you are seeking assistance, may I suggest you provide more information about your fridge, like brand and model number.
If it was a Fisher & Paykel, and it was beeping, count the number of beeps. This will indicate the fault code. Report back with that information
Dec 02, 2016 | Refrigerators
Why did door alarm suddenly start going off every time I open the fridge or freezer?
Hi Christine.
When your F&P beeps, it's indicating a fault code - count the beeps which will relate to a fault code. 17 beeps would indicate an issue with the freezer fan.
Could be the reed switch (door switch).. amount of beeps will indicate the fault code.
Dec 14, 2015 | Fisher and Paykel E402BRXFDU Bottom...
Compressor running continuously. Hearing surging sound. Both fridge & freezer not cooling.
there may be a blockage in the evaporator tube in the fridge sections and the only way to establish what the fault is will be to have fridge technician run test on it
Jul 25, 2015 | Fisher and Paykel Active Smart E522B...
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
OK I have the RF610A fridge on top and freezer below in french door arrangement.
Have you checked the fridge thermostat? If the thermostat is ok then you should trace the volts which operate the valve which connects the compressor to the fridge evaporator coils. If the valve is getting volts then the valve is faulty. If not fault lies with control circuitry.
May 08, 2014 | Fisher and Paykel Refrigerators
I have a 10 years E521T fisher & paykel. The freezer compartment is working fine, however the fridge compartment is not working even adjust temperture. It's beeping and can be reset with pressing
From thee sounds of your issue you will need a sensor or a fan motor to move air from one section to another. Most likely this would be a fan motor located within the freezer section either not running or air flow is obstructed and can't leave the freezer section to enter through passages to cool the other section. Locate the air ports within the refer section, open freezer door (is there air coming out of air port in this section?). Now, close door to freezer, (is the same air flow still there?). If not you have an air flow restriction and this would need to be addressed. Good Luck, hit me up if you have more questions
Apr 04, 2014 | Fisher and Paykel Active Smart® E522BR...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
220 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
