My washing machine, made by LG and model WD10162F, wont release the water so I have to release it manually and not even then it have a 100% succes rate. So my question is what can i do about it, or is it time to upgrade to a newer model?
SOURCE: Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Posted on Jan 02, 2008
michiganfan9
  • 179 Answers
SOURCE: Kenmore model 22432100 - it won't drain or spin
sounds to me that something is stuck in your pump check the pump if you open the pump have lots of towels on hand the machine will not spin if it does not drain
Posted on Dec 29, 2008
Dinu_kool
  • 44 Answers
SOURCE: Owners manual for LG, WD 14336ADK
www.asm-service-manual.com/List/LG%20List%20ASM.htm
use the above link to download the owners manual
Posted on Mar 20, 2009
  • 714 Answers
SOURCE: water not leaving machine
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 17, 2010
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
LG Semi Automatic WP 9220 washing machine water is not draining out what to do
Enter your model number into the self help section of repairclinic.com, you will receive specific trouble shooting info for you appliance.
May 11, 2015 | LG Washing Machines
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
I have a 6.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? The call out fee is $100 and $20 per 10mis ...
The water solenoid valve may have gone bad and is allowing water to enter. Turn off the cold water shut off valve at the wall to immediately stop any water from flowing. What is your machines model number?
Jan 15, 2015 | LG Washing Machines
LG Washing machin model : LG-WFF734PC Top Loading having problem , water keep coming out through the drain hose when the the water flow in the tub for the first process of washing. Every time i selected...
you will need to take the back off the machine to access the small 5mm pipe that Leeds upward to the water sensor and take it off and blow gently into it when you do you will hear a click and one when you release the air that means that the sensor is ok but the tube where you took it from is blocked with soap goo unblock it and the problem should be gone eric
Dec 27, 2017 | LG Washing Machines
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
I have an LG washing machine model WF-T755A After washing completed, if water not turned off at taps, the unit slowly fills up with water. The last time causing it to overflow and flood the floor
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
Aug 31, 2008 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG washer uses so little water, clothes aren't even damp and not clean
You will need to have a qualified LG technician come out and see what the problem is.  You may have a water level switch issue.
Jul 11, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
113 people viewed this question
Top Washing Machines Experts
