Question about Pioneer DEH-12
I have a Pioneer DEH-12A Car Sterio. How do you get the radio on? I put a CD in the player which works just fine but when I eject the CD from the player nothing happens. So, what button or buttons switch the player from CD to Radio? I can't get the radio on at all and I have pushed every button. Thanks
5 Suggested Answers
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
shawnsz
  • 64 Answers
SOURCE: pioneer DEH-P500UB set the clock
1 Press SRC and hold until the unit turns
off.
2 Press MULTI-CONTROL and hold until
CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select clock set.
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour—Minute
As you select segments of the clock display,
the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Posted on Feb 18, 2009
  • 5 Answers
SOURCE: Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Posted on Mar 25, 2009
  • 68 Answers
SOURCE: wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Posted on Nov 17, 2009
I got a premier, pioneer DEH-P200 sterio and ive hooked it up to my 92 chevy truck and my 94 camero but in both it powers on. and beeps through the cd player for volume changes and stuff like that but its...
WELL THIS RADIO CD PLAYER WILL NOT WORK WITHOUT AN AMP HOOK UP IT JUST SENDS A SIGNAL TO THE AMP AND THEN TO THE SPEAKERS. YOU MAY HAVE TO FIND THE AMP THAT DIRECTLY HOOKS TO THIS UNIT...
Jul 15, 2011 | Pioneer DEH-P200 CD Changer
First, my Pioneer DEH-P3800 detachable face receiver worked fine. Then it got to the point where about once every 10-15 times one would press the eject button, the CD would eventually eject. However, the...
you may have a dirty pinch roller. it can be cleaned with qtips and rubber revitalizer. do not use rubbing alcohol or anything else. you can try dry qtips, it might work temporarily.
Aug 29, 2010 | Pioneer DEH-P8MP CD Player
How do you eject the damn cd out of the pioneer DEH-P7900BT
Your Manual
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/429287552DEHP7900BTOperationManual0328.pdf
will go over all the functions in detail.
3 EJECT button
Press to eject a CD from your built-in CD
player.
Press and hold to open or close the front
panel.
Bottom rightmost button.
Nov 11, 2008 | Pioneer DEH-P7900BT CD Player
Pioneer deh 1100 problem
your fuse that is in the car is most likely th problem.Your radio is fine. Replace the fuse check the owners manual to locate the memort for the radio
Aug 28, 2008 | Pioneer DEH-1100 CD Player
Pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
May 13, 2008 | Pioneer DEH-P840MP CD Player
Cd will not eject
do you hear it trying to eject?
Oct 26, 2007 | Pioneer DEH-P3600 CD Player
Pioneer DEH-1900MP error AO
I have the same problem CD will not eject and getting error :S
Oct 19, 2007 | Pioneer DEH-1900MP CD Player
Car Audio & Video Logo
245 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
