Question about Swimline 10 X 15ft Oval Beaded Caribbean Pool Liner 48" Depth
I had this liner installed 3 years ago but i have the one that looks like there is sand on the bottem not the blue one it is so stained that it is making my pool water look green. what can i do
    Problem Solver:
  • 12 Answers
Ck chemical levels to verify it's not green. Baking soda may help clear it up some. call the liner people and see if they've any idea's
Posted on May 30, 2011
I have two little round stains on my Swanstone kitchen sink and I would like to know how to get them out. I dripped liquid skin in small part of the sink and everything I have tried does not work. A
You will lose any gloss you may have left after 20 years, but i'm pretty sure Swanstone is similar to Corian in that you can sand the stain out. Start with a 180 grit and after the stain is removed you will want to wet sand it with a 250 to 400 grit.
Oct 09, 2014 | Swanstone KSDB-3322 Double Bowl Kitchen...
REPLACE POOL LINER
Good luck on your warranty. I'm sure it will be pro-rated. 10 years is a long time for a liner to last. It usually costs 2,000-3,000 for a new liner and installation.
Jul 11, 2014 | GLI Pool Products Pool & Spa
Have an Intex 12ft x 3ft metal frame pool. Set it up first and filled it and it lost more than half the water overnight. Did everything I was told to find the leak and nothing. Was on hands and knees in...
what is not included in the instructions is the simple " lay down a bed of filter sand around 3" thick before placing liner in the pool frame and radius it up at the bottom corners
that sand is necessary because any small pebble , rock or edge will cut the thin liner under water pressure or feet walking in the bottom of the liner
further more , if you use chlorine as a cleaning , antibacterial agent that will cause pin holes in any part of the liner not completely covered by water
Mar 26, 2017 | Sport & Outdoor - Others
My filter has only been used for 2 months, it seems like there is sand on the bottom of pool, I just had new liner put in because the sand crystallized last year and I couldn't get it off. The filter...
Hayward should stand behind their filter. If the unit is only two months old, the seller should be helping you. If there is sand in the pool, it is because on the bottom of the filter is a distributor which is tubing with many thin slits. The slits are small enough that sand can not get through. If a piece of the tubing breaks or if it is not installed tightly, sand will continue to get out and into your pool. If you Google Hayward, I'm sure customer support will be able to help you.
Gary
Jun 30, 2011 | Hayward SAND FILTER, PRO SERIES
I have a Hayward 160T high rate sand filter. How often should the sand be changed? Can you over shock a pool when you first open it? What type of sand and where can I get it?.
Q. I have a Hayward 160T high rate sand filter. How often should the sand be changed? Every 3 - 5 years.
Q. Can you over shock a pool when you first open it? Only in the sense that a liner or some of the equipment will not like ultra-high chlorine levels and depending on the shock used you can mess up pH and Alkalinity...generally you shock with one pound per 10K gallons.
Q. What type of sand and where can I get it? #20 silica sand...some places will call it fine sand. Do not use the coarse or medium coarse sand.
John
May 29, 2011 | Hayward Pool & Spa
I am thinking of buying this truck for $700 not sure if the k series 1,500 all the add states is that it's a 98 chevy 1500 pickup 2wd . this is the ad .Blue 98 Chevy 1500 Regular cab 8' bed with...
it is the c1500 being 2wd k series is 4x4. sounds like it is worth the money. will just need to do the basic checks to start with. fuel pressure,spark,compression and so on to narrow down problem.
Dec 13, 2010 | 1998 Chevrolet K1500
Cleaning glass cooktop surface
I used Mr. Clean multi-surface and the green, back side of the sponge. Turned on a light to show visible stains better, and scrubbed away. It didn't scratch the glass and got it out quick. Hope this helps.
Jul 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
Swimline 10 X 15ft Oval Beaded Caribbean Pool Liner 48" Depth Logo
53 people viewed this question
Top Swimline Garden Experts
Dennis Key
Dennis Key
john h
Are you a Swimline Garden Expert? Answer questions, earn points and help others
