Question about Dryers
I replaced the belt and need to know how the tensioner goes back on
  • 127 Answers
From the front with the belt around the drum in the correct position, and the drum in place. Reach in under the drum and put the belt around the pulley on the drive motor. Then find the idler pulley. It should be pulled to the base of the drier to the left of the drive motor pulley. Pull the idler pulley up and to the right and place it on the outside of the of the belt coming down from the drum to the drive pulley. It should pull back to the left and tension the belt.
Posted on May 30, 2011
NEED TO PUT THE DRUM BELT BACK ON ASAP
The other pulley is spring loaded it puts tension on the belt.
Pull the pulley back and the belt will slip ight over then release the tension pulley and your done!
Apr 17, 2014 | Haier HLP140E Electric Portable Dryer
Need diagram for 2001chevyprismserpentinebelt
Aug 16, 2011 | 2001 Chevrolet Prizm
Need to know where the tentioner pully goes to put the belt back on
Difficlut to specify as you did not indicate the make or model of your dryer, but usually the tensioner goes into slots on the machine base, and the belt holds the tensioner off of the interrupt/safety switch...
Feb 25, 2011 | Dryers
Replace serpimtine belt
pull tensioner back to release tension on belt ,,make sure you write on paper how belt goes on vehicle,make a diagram,remove belt,put belt back on the same coming off,move tensioner back so you can get belt back on,,,tensioner looks like a pully with a bracket that moves,should be 3/8 ratchet type insert or wrench style to move tensioner
Nov 24, 2010 | 1999 Ford Taurus
How do i replace the serpentine belt that goes tothe alt. ?
You will need a breaker bar to release the tensioner. A breaker bar is a long ratchet that doesn't ratchet. The breaker bar size for your car is 1/2".
You will see a square hole on the tensioner and that is where the breaker bar goes. Put the breaker bar in there and pull on it until it gives you enough slack to pull the belt off. Make sure to pull the right way to release the tension. IF it wont release the tension don't yank on it try going the other way, It will help to have two people to do this job. You only need to pull it off one pully then slowly let the tensioner go back.
To put the new belt on make sure you run the new belt the exact same way as the old. Again you will need to release the tension from the tensioner and slip the belt over the last pulley.
Subikid90
Mar 03, 2010 | 2003 Kia Sedona
Steps to replacing the serpintine belt
release tension on belt by:
-put a socket/breaker bar or ratched on the tensioner pulley bolt and use it to relieve tension on the belt
-slide belt off tensioner pulley. replace with new belt in same pattern across all pulleys and again relieve tension on the tensioner puller to slide the new belt back on
--you may need to remove the bolt on the tensioner closest to the pulley (i don't know just judging by the picture i found)
---if you don't know what the tensioner looks like look up the part on autozone's website for a picture you can match on your car
Jan 10, 2010 | 2005 Toyota Corolla
We need to replace an alternator belt on a 2001 saturn sl2 series
YOU MEAN THE CERPENTINE BELT?? IT ONLY HAS ONE I BELIEVE. BELOW THE TOP FRONT ENGINE MOUNT THERES A BELT TENSIONER PUT A WRENCH ON THE CENTER BOLT AND TURN IT TO LOOSEN THE BELT, (INSTALATION) TURN THE TENSIONER TO PUT THE BELT BACK ON. AND IF YOU FORGOT THE WAY THE BELT GOES BACK ON, CHECK THE DECAL BY THE RADIATOR AND YOULL SEE THE PICTURE HOW IT GOES.
Jan 01, 2010 | 2001 Saturn SL
Dont know how belt goes
if you are going to replace your belt and you get it at Autozone,the belt routing will be on the package,but you need to check the automatic belt tensioner to see if it is still spring loaded,it bust not be since your belt came off,
Dec 26, 2009 | 1993 Chrysler Town & Country
How do you replace an auto tensioner (serpentine belt pulley) on a 2000 Plymouth voyager?
take the pressure off the belt and move belt off the tensioner then unbolt it and remove then bolt on the new one then put pressure on tensioner to put belt back on (make sure you see and know how the belt goes back on incase it comes off more than you intended)
Nov 20, 2009 | 2000 Plymouth Voyager
Belt tensioner
there is a bolt that u need a special tool to get to and if u turn it towards the back of ur car it will get tension
Oct 10, 2008 | 1997 Ford Taurus
Dryers Logo
59 people viewed this question
Top Dryers Experts
