Question about Bissell ProHeat Deep Cleaner Upright Vacuum
When i use my machine it is only using the cleaner and not the water. What can i check or do?? Thanks
  • 23 Answers
Pump is bad
Posted on May 30, 2011
I stored my FH50220 in my storage unit over the winter and now it will not spray water
If your storage unit got below freezing it may have frozen and damaged something. It's hard to drain all of the water from pumps, tubes, valves, heaters etc. inside a carpet cleaning machine. If a machine must be stored where it may freeze one way to keep it from freezing up is to pour automobile windshield washing solution into the fresh water tank and run it through the machine until it comes out all of the Jets and cleaning attachments. Remove the fresh water tank and continue to run the solution through the machine to flush the windshield cleaner out of the machine. Be sure to use a cleaner with the proper anti-freeze rating and run fresh water through the machine before using it to clean carpets.
Apr 01, 2016 | Hoover FH50220 Vacuum
Tip
How To Fix Your Bissell Carpet Cleaner When Solution Won't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
on Apr 12, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have the bissell pro heat turbo microban cleaner. It's about 2 1/2 years old and maybe used 8 times. The brushes do not work and it's not suctioning up the water. I've checked the belt on...
You already said it, so check the carbon brushes. Once it is no longer able to push the rotor or stator it need to be replace. Carbon brushes are customized at the machine shop, so you should bring it so that you have a sample of the brushes itself. Just be observant when disassembling the motor so that you put it back to exact place.
Thanks for asking.
Jul 13, 2011 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover Steam Vac ; The vac is not dispensing cleaner/water. I suspect the tubing/path from tank holding the cleaner/water mixture is clogged. Is there an easy way to unclogg it. Are there are...
Just a quick clarification please. Will the water not spray in both the attachment hose as well as the floor part? Or does it spray in one or the other. You suspect that it may have a clogged line, is the machine doing anything in particular that makes you think a clog?
Thanks,
CJ
Apr 18, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
I have a billell Pro Heat 2X without a manual. How do I fill it and what ratio water to cleaner?
The cleaner goes into the small bottom at the very rear of the machine. It is uses full strenght (don't add any water to it). You add clean water into the bottom clear plastic section on the front of the machine. The clean water bladder is soft plastic and it is filled from the top. When you start using the machine, the dirty water will get suctioned into the section surrounding this bladder. The machine will stop working when either the bladder is empty or the dirty water section is full. Remove the entire plastic section to dump out the dirty water.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Tank not collecting dirty water
You most likely have a break in your suction hose. check at the base where it attaches. When you bring back the handle release, you can see lt. If you have the type that has the external plug in for the water, then you probably don't have the hose part plugged in to the collection tank. in the front of the collection tank. Your motor shut off? Well, If you have the first variety cleaner w/built in hose, you may have sucked water into/onto your motor. If this is the case you need to bring it for service. otherwise, you could have a blockage in your collection hose, this would also explain the machine shut down, from the thermosat. A clogged machine will ultimately overheat, wont run again till cooled.
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Jun 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Aqua vac vacuum cleaner
yes you do need water... but water vacs dont clean as well as a good old suction driven machine.... aerus has several great models available
Feb 05, 2008 | Vacuums
Bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Nov 06, 2007 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat Deep Cleaner Upright Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
