Question about Microwave Ovens
I have a ge Gss25xsrass about 2 weeks ago the water/ ice dispenser on the freezer door stop working. I noticed the red/black and blue wire that run from the bottom of the door to the wire harness under the freezer have corroded and broken free. I tried to rewire it but can't rewire without the thermostat/ turbo cool in the refrigerator loosing power. Is it possible to buy a new wire harness? Or am I in over my head and should just call for a repair?
  • Idoc6 May 30, 2011
    Thank you. I rewired everything leading to the in the door controls and the thermostat bypassing and replacing the bad conector. Everything seams to be working ok
  • 10,319 Answers
I would diffenetly call for a repairman for the harness will take a long time to receive and with loss of power can cause food loss depending how much trouble you have repairing it
Posted on May 30, 2011
    Genius:
  • 1,157 Answers
Hi Idoc6,
The thermostat is connected by two wires. These wires are connected with slip on connectors or a wiring harness. You can firmly pull the connectors or harness off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the thermostat for continuity using a multitester. Set the multitester to the ohms setting X1. Place a probe on each terminal. The multitester should display a reading of zero when the thermostat is cold and a reading of infinity when it is warm (40 to 90 degrees F depending on the model). If the thermostat does not pass this test it should be replaced.
If you're not familiar with the procedure, I would highly recommend to consult an authorized repairman to prevent further damage on the unit.
Hope it helps.
Thank you for using FixYa.
We stopped getting water from our Kenmore freezer door dispenser. I have verified the solenoid valve is working. The line from the solenoid outlet to the dispenser appears to be plugged (can't blow...
Many times the lines get frozen as they run through the back of the refrigerator section. Sometimes simply turning the temp up in that section will open the lines. Additonally, you might have to remove everything from the unit and totally defrost it to clear it. IF it's Ice.
Do you use a filter for the water comming into the unit? IF not you could have a blockage. If that is the case you will have to find where the block is and remove the block.
Jul 23, 2011 | Microwave Ovens
Hi, I have a amana fridge with freezer on the bottom. It has an ice maker and water dispenser. The big problem is a buzzing noise comming from the fridge, it start aprox every 16 min and buzzes for 10...
The buzzing you hear is the water valve trying to run water to the icemaker. If there is no water going to the icemaker it will be going into cycles one after another. And when it does it adds heat into the freezer. Turn the ice maker off and see if the freezer gets colder.
May 20, 2011 | Microwave Ovens
SMEG FA550X fridge freezer. The ice maker has stopped working, freezer has thick ice built up at bottom, fridge does not appear to be keeping food cold enough as milk etc is going off quickly. Two to...
Your Ice maker may be the cause. if it is not holding water the water may be landing on the bottom and freezing, causing the ice build up and obstructing the air transfer from the freezer to the refrigerator. You can remove or replace your Ice maker. Then you will have to defrost your freezer to get everything back to normal.
May 11, 2011 | Microwave Ovens
I am getting power and the freezer appears to be working but the fridge is not cold at all, any suggestions? Many thanks Dave McRae
Hi Dave and welcome to FixYa, I am Kelly,
Take a look in the back of the freezer compartment. Look for any signs of icing on the back access cover. Usually but not always the evaporator coils freeze up because the unit is not automatically defrosting properly or there is a problem with the evaporator fan not running fast enough / at all. Press gently with your hand of the back cover of the freezer compartment and feel for ice. Also check the front of the chassis for signs of being HOT. It is ok to be warm not hot.
Also check to see that the light goes on and off as you actuate the light switch plunger. Some units have the door switch in the top of the door hinge but most have the switch in the door fold area of the chassis some where.
If you find that the evaporator coils have iced up:
  • Perform a manual defrost of the unit but first unplugging it
  • Remove the freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hrs. (makes a water mess)
  • After 2 hrs clean up the water mess and return the unit to normal service.
  • Watch after 3 days if the fresh food compartment once again starts warming up. If it does you have and automatic defrosting problem.
No ice noted:
  • Possible temp control problem (Thermostat / cold control or thermistor)
  • Possible Air Damper problem. There are 2 kinds of air dampers. One is electrically controlled and the other is nothing but a mechanical baffle that is positioned partially open. If you have the electrical type the air damper motor may have failed or the movable baffle is stuck.
Front of chassis is almost HOT to the touch vs warm:
  • Open the back of the unit by removing the black fiberboard cover and inspect for lint and that the condenser fan is running anytime the compressor is running.
Light always on:
  • Door switch failure. Some door switches also control the evaporator fan along with water in door and ice in door functions. The water and ice in door should NOT work with the door open.
The above is pretty much an in home repair techicians check list for the symptom you describe.
If you discover that you have an automatic defrosting problem I will need you MAKE & MODEL number via your next response here so I can tell you what you can do to troubleshoot. (
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Microwave Ovens
Ice maker will not make ice
hELLO THERE:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Dec 29, 2010 | GE Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Kelly
Oct 26, 2010 | Microwave Ovens
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Turn on the microwave, it runs but doesn't heat anything.
It's probably one of the switches that cuts the power to the microwave when you open the door. Mine is GE 700 watts and has 3 of those, and the one in the middle went bad so a week ago I temporarily bypassed the switch (while I get one) by cutting both wires that go to the switch and put electrical tape at the end of each wire. The switch was supposed to be a normally open switch but it had continuity with the door open or closed, and it should only have continuity (be closed) when the door is open.
Apr 10, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
