Question about SMC (SMC7004AWBR) Router
Smc router says limited connectivity and won't work.
  • 151 Answers
I experienced the same issue before with my route,try doing these steps im sure this will work somehow. (flush the DNS cache)
How to do it:
If you are using Windows 2000/XP operating sysytem
-Fire up a Command Prompt (Start Menu>Accessories) and execute the command
ipconfig -flushdns
if you get 'could not flush dns' or message saying dns resolver cache could not be flushed.
If it is XP SP2 then go to Start > Run > CMD > type netsh winsock reset > enter, restart as prompted, if still no connection then go to Start, Control Panel (Network and Internet Connections then Network Connections -or- straight to Network Connections, double click on the Local Area Connection in use (usually the one that says Connected) and pick Support. Try the Repair button after Winsock fix. Use that winsock fix only if you are using SP2.
go to "start, control panel, administration tools,services,then look for DNS Client, and make sure it's started, and set to manual.
Posted on May 30, 2011
Limited access
Easy put all settings on dhcp and reboot system
Dec 31, 2013 | SMC Computers & Internet
Installing SMCBR14UP printer with wireless connection
Let say you had Win7 then just select "add a printer" after look for 'devices and printer" in the Start section.If you find a printer there just delete it and then "add a printer" and follow the wizard.Note thta it will be wireless so try the IP you use in the Mac PC.
Jun 17, 2012 | SMC Barricade SMCBR14UP Router
I disabled my smc wireless through the ip address provided. When I went to reable it, the ip page won't load?? Help please
You might be connecting through wireless before and now that you have disabled it, your computer is not connected to the router and that is why you are not able to display the setup page. You can use an Ethernet cable to connect your pc to the router. Once connected, try to load the router's setup page again through the provided ip address. If you are unsure about your router's ip address, check this out for guidance. click here.
Hope this helps.
Jun 27, 2011 | Computers & Internet
I have installed a SMC2862W-G wireless usb adapater on my pc. it is recognizing my wireless router and it is showing a decent signal strength in the SMC utility. However, my wireless connection icon on my...
You need to install the driver disk that came with the USB adapter. Your PC correctly pointed out that the internal WI-FI adapter is not working but the USB adapter should be showing on the taskbar of the driver is installed correctly.
Mar 08, 2018 | SMC EZ Connect g SMC2862W-G 802.11g/b...
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
How can I limit the bandwith on an individual
you cannot limit the bandwith, but you can give limited access to a particular user/computer. You would need the router manual to figure it out.
Sep 28, 2009 | SMC Barricade 7008 Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
One computer connected the other limited or no connectivity
When using a router your IP is assigned to your Router. Then Your router assigns IP's to whatever is hooked up to it. Set everthing to detect automaticly. Might delet connection and create a new one.
Mar 11, 2009 | SMC Netgear 5Port Gigabit Ethernet Switch...
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Software malfunction
I assume they told you to uninstall the software, remove the adapter, then re install driver an re insert adapter, as this normally cures the driver fault. If they didn't try that, if the problem persists the adapter may be faulty although i think it's a software problem. Try not to use Windows to repair connection as it never works and resets your pc's ip address differently than your routers already given it.
Jan 24, 2007 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC (SMC7004AWBR) Router Logo
227 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
