Question about HP J4680 Office Jet All-In-One Printer
My printer is saying that it is out of paper put there is paper in the tray. I have tried changing to different thickness of paper and I am still getting the same issue. I have only had this printer for about 1.5 years and I rarely use it.
    Guru:
  • 731 Answers
Try partial reset as per below instruction
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Regards
Riztech
Posted on May 30, 2011
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
My Konica Milnolta c224e display massage bye pass try could not be loaded
Sure it say that exactly never heard that before doesn't say "Replenish paper"? or does it give a code or jam indication
Is there any paper on it does this happen when printing or copying ? Trying to print paper or envelope? Do the draws work OK? If printing send the print job to the machine first the when the copier states replenish paper for the bypass tray put the paper there. insure your printer perfrancies match your setting on the copier for the bypass tray, such as THICK 1 or what ever
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 03, 2015 | Konica Office Equipment & Supplies
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
My toshiba copier keeps saying job status change paper type. how do i get it off that? thank you
Your copier is likely trying to print to a different thickness of paper (ie thick 1/thick 2) then you have in whatever tray it is trying to print from. You will either have to change what is in that drawer via user functions or delete the job and try it again with a different paper type.
Sep 07, 2010 | Toshiba E-STUDIO 720 Copier
Problems with duplex printing
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
May 27, 2010 | HP LaserJet 2300 Printer
Doesn't pick up photo paper -
So in other words, the printer jams when you put in photo paper, but not with normal paper?
Check your printer to make sure it supports printing to photo paper. If it does, check to see what kind it supports. There are different thicknesses of paper and the one your putting in may be too thick.
Apr 05, 2010 | Office Equipment & Supplies
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
How do you change the paper selection?!?
if you have a different size/type paper in trays, just choose auto tray from printing preference, you only have to put right paper type /plain/thick ..... and the printer find it self the right tray
Oct 28, 2008 | Konica Minolta bizhub C250 All-In-One...
Wont print on card stock, legal paper- keeps jamming
Menu> scroll to Paperhandling> MP Tray type>>(plain) try changing this to cardstock  <enter>
instead of MP Tray type do the same for Cassette if you desire....
Best, danakadan
Oct 11, 2008 | Kyocera FS-1030D Laser Printer
Not noticing paper
I took an envelope, folded in the end to triple its thickness and placed it in the middle of the paper tray underneath the very last page. This pushed the center of the paper up more and it had no problem detecting or getting hold of the paper. Have to be sure the paper supply tray is full though. When it gets to the last five or seven pages it has difficulty again. It's a nontechnical fix, but it seems to work.
Dec 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
HP J4680 Office Jet All-In-One Printer Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
