Question about Boxlight CP 310t Multimedia Projector
Boxlight cp-310t won't display image
I dropped my projector accidentally a few weeks ago, but everything has been fine until today. The projector turns on and projects, but it doesn't display anything - not even the menu when I press the menu button. I just got a new lamp, and I'm not sure but the projector may not be projecting as bright an image as it was before. I can't tell, though, because it's just projecting black. This morning the projector worked fine, so I don't know what's up. Thanks for your advice!
  • 2,237 Answers
Loose connection. possible crack on main board. needs to be sent in to have a look at.
Posted on Aug 19, 2009
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Boxlight cp-310t won't display image
loose connection
Posted on Dec 23, 2009
My light comes on dim then goes off an the thing still run a fan and look like it on??? please help
it's either the lamp or the ballast. check the inside of the lamp. if you have bulges, black spots, flaking or fogging, replace the lamp. if the lamp is ok, replace the ballast.
Jan 01, 2010 | Boxlight CP 310t Multimedia Projector
Hitachi line problem
the horizontal is given out ont the project it will need to be service. or the part ordered and you fix it your self.
rod
Feb 05, 2009 | Hitachi CP-X985 Multimedia Projector
Boxlight CP-670K no video
change cables, and then check the resolution. it doesn't do digital video.
Jan 26, 2009 | Boxlight SP 6t Multimedia Projector
Do you know any sights for to view Boxlight manuals online?
you can try www.projectordoctor.com. if you don't see the link for it, scroll down to see if the model is the same as other brands. some of the boxlight projectors are made by sanyo and infocus.
Sep 27, 2008 | Boxlight CP 310t Multimedia Projector
Shadowing on a Boxlight 6000E
look at the diffuser lenses just after the lamp. there should be 2. the second one tends to have burn spots after a while in dusty and hot conditions. if the lens is ok, look at the lcds with the light on. do you see shadows on the panels? if so, you have a main board issue. if not, you have a misaligned mirror.
Jan 21, 2008 | Boxlight CP 10t Multimedia Projector
Projection Problem
send it in for repair. one of the diffuser lenses, the lcd panel, or the lcd frame are loos and need tightening.
Dec 19, 2007 | Boxlight CP 10t Multimedia Projector
Lamp shuts down after startup
it is the power supply/ballast. when you first turn it on, the caps on the ps/bal charge then discharge when the lamp is to strike. if the caps are dried out (from excessive heat), it takes a while to build a charge. so the power drain from striking the lamp brings the ps/bal into shutdown. after you try again, the caps are now up to full power and everything is fine. but every time you unplug it, you'll have the same problem. replace the power supply and ballast.
Dec 11, 2007 | Boxlight CP 19t Multimedia Projector
To blue
reset the settings to factory default and swap out the cable you are using. if that doesn't work, you need to check the polarizers on the lcd panels. if they are burnt, you'll need to replace them. but since boxlight doesn't sell individial parts to the optical engine, you'll have to replace the whole engine.
Dec 07, 2007 | Boxlight CP 310t Multimedia Projector
Boxlight CP 310t Multimedia Projector Logo
140 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
