Question about Microsoft Windows XP Professional
Everytime i turn on my pc,it beeps 3x(1long then 2short),then black screen so i have to reboot again
  • 151 Answers
Here are the following steps you can try to fix this issue, ive experienced it myself using a dell PC and it works on my end.
You have what is called a No Post No Video Situation.
1: The Modem can cause a No Post No Video. Pull it and see what happens.
If it still does not boot. Strip the System down with nothing on the Board but Power Supply Processor and Fans.
This Includes All Memory, All Cards, All IDE Cables. Hook just the Power up and See if you get Memory Error Codes ( Beep Codes ). If you Do ( And you Should ) then Reseat the Memory ONLY. If you dont more than Likely it is the Power Supply or Motherboard.
If Reseating the Memory back in Memory Bank 0 causes a No Post. Pull the Memory and put the Memory in Bank 1. If it Post then Bank 0 is bad on the Motherboard. If it Dont, You Need Memory. If you have more than 1 stick then try with one or the other and make sure one of them is not bad. If it is Rambus Memory you will need to add both sticks, because Rambus is Required for Pair.
If in Bank 0 the System Posts, add the Video Card and connect the Power and Monitor. You should get Post and Video. If you do not, Video Card is bad.
From there add the Hard Drive IDE and Boot the System. If it does not boot then try the IDE Cable in the CDROM Controller and see what happens. If it Boots then the Controller on the Motherboard is bad. If it Causes a No Post No Video, Hard Drive is Bad.
From there Add One IDE Back at a time and make sure it is none of those drives or Controllers. If you find that one of the Drives is causing a No Post No Video, Try a Known Good Drive. If it Posts and Boots. The Drive is Bad. If it Dont, The Controller on the Motherboard is bad.
After that Add one card back at a time. Find out which one is causing the Issue. Sometimes Reseating everything works fine. If none of these work then You May have Either a Bad Power Supply or a Bad Processor. Also dont forget that you may have had a Surge or Storm and May have Caused a the Motherboard to get damaged.
Dell has a Good Artical on Steps to do for this at http://support.dell.com/us/en/kb/document.asp?DN=TI1014149
Posted on May 30, 2011
  • Robert Toth Jun 03, 2011
    If he is getting no POST, how come he has beeps?
    Problem Solver:
  • 17 Answers
CHECK YOUR RAM.
Posted on Jul 03, 2011
One short and two long beeps means you have vidio card troulble. It could be the driver, or you might need to reset the card, or the vidio card needs to be replaced.
Posted on May 31, 2011
  • Robert Toth May 31, 2011
    To be exact mono/CGA display circuitry issue, that would be the first place to look befor you disasemble your system needlessly, however sometimes disasemble is the only way. R-toth
1long beep 2 short beeps on laptop when turning on black screen
login to the computer manufacture with make and model , request latest driver.
Nov 19, 2016 | Computers & Internet
Everytime i boot my pc,it beeps 2x,then black screen,so i have to reboot again
The beeping is caused by your computers POST( Power On Self Test - learn something new everyday! ;) )
Find your motherboard manual, and have a look in it for beep codes, or error codes. The number of beeps will let you know what kind of problem you're dealing with.
If all is well in POST, your computer should only beep once, and continue.
Can you get into BIOS at all, or does it just show you your videocard info on bootup, then black screen?
May 27, 2011 | Microsoft Windows XP Professional
As i turn on my pc, i hear 1long and 2short beep..and the light of the monitor power is blinking..what could be the problem? Hope that you can help me..TNX
The beep code you are getting Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information. Plan English - you have a bad video card or port. If your video output is on a PCI card, replace the card. If it's on the board, you will need to replace your motherboard.
Good Luck
C2Solutions
Jan 19, 2011 | Computers & Internet
Aspire 5100 beep 1long 2short power indicator on but no screen
first check the VGA able.. if VGA not work supply not comes to monitor
Oct 14, 2010 | Computers & Internet
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Pc shutsdown after 1min or so
follow this steps bro. 1. restart your pc. 2. press delete button till 1long beep correspond while on reboot mode. 3.configure your BIOS and set first boot for cd or dvd rom drive. 4.insert your windows xp installer that u've use, then just select repair mode operation to fix your operating system files.
May 15, 2010 | Computers & Internet
Video card problem - laptop screen blacks out.
it may be possible tht u need to upgrade ur video card memory
Jun 19, 2009 | Acer Aspire 5000 Notebook
No display on screen only 1 long beep then 2short beeps
This is a memory error. First remove all your memory then put it back in again. If the error persists and you have more than one memory module, remove one at a time and see if it will boot. If you only have on module, then that module will have to be replaced.
Jun 14, 2009 | HP Pavilion dv2000t Notebook
Gateway c140 beeps
If you have an AMI bios (you can tell when you boot and the black screen has writing on it at startup - the bios type and version is the first thing at the top of the screen)
1 long and 3 short beeps indicates that the memory is not seated properly. You should check that it is secure on your motherboard. If it is seated securely, your memory is maybe faulty.
Mar 21, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
172 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
