Question about Refrigerators
Our PFS22MISBWW fridge and freezer are the same temperature as my kitchen inside. Its around 4 years old. I've unplugged it, cleaned it out, vacuumed out the back bottom area, and waited 20 minutes before plugging it back in. After plugging it back in I hear a short "click" in the area of the back bottom area on the right (if you are looking at it from the front). about a minute later it begins to whir like it wants to start up and continues to "run" but every minute or 2 the same "click" happens, and it is not getting any colder after several hours of listening to my fridge "run" and "click."
    President:
  • 662 Answers
Your nicely detailed and well worded question gives all the clues needed to suspect that the
compressor motor is effectively dead. What's happening is that the motor (correctly) receives input
from the control circuitry of the frig to turn on (to cool the interior of the frig) - it turns on, quickly
overheats (within a minute or two), and then the motor's thermal shutoff kills the overheating
motor (with a "click"). Then the motor cools for awhile, the thermal cutoff eventually resets
and allows current to the motor, which tries to run again, but quickly overheats again, etc.
Posted on May 30, 2011
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Model ZHSC02PP-- Mini fridge no longer cooling (18-24 months old)
Has it sat any amount of time without usage? Check and see if any of the 4 walls is cool, it could be that the fan isnt working.
Jan 30, 2012 | Haier Refrigerators
Fridge too cold!
don't forget that just turning down your fridge temp dose not mean your problem might be over yet. the freezer setting may also be too high & that will affect your fridge temp as well. i set both my control settings to around 50% of what is on the scale & that works perfect for my 7 yr old fridge. also, very important, is make sure the freezer portion is going through it's full defrost cycles, or it will freeze the upper portion inside the fridge. you should not have any frost build up in your fridge, nor should you have any in your freezer. that's why they call them FROST FREE. try the slow temp decrease over a period of a few days & hopefully that will work for you. good luck.
Dec 01, 2011 | Refrigerators
Refrigerator/freezer not cooling. Model Number: 106.42102301.
Kenmore brand refrigerators offer energy efficiency and space saving benefits with a range of innovative designs. The company's refrigerator-freezer units are manufactured in traditional top-mount freezers, bottom-mounts, and side-by-side styles. Occasionally, as with any brand of appliance, the components can malfunction and cause the freezer to stop working properly. A few troubleshooting steps can help locate the problem so that it can be repaired.
  1. Power Supply
    • Occasionally the power cord to your fridge slips out, or the outlet it's connected to is defective. Before troubleshooting other potential problems, check that your fridge is plugged in, and if it is, try plugging something else into the outlet to confirm that it is working. If there is no power, check the fuse or circuit breaker and replace or reset if necessary.
    Thermostat and Compressor
    • Freezers rely on the thermostat to know when to turn on the compressor and when to turn it off. Thus, the thermostat controls the temperature in your fridge. Typically, for a Kenmore refrigerator, the recommended setting for both the refrigerator and the freezer is 3. Check that both are set properly and if they are, try setting the freezer's thermostat to a slightly colder setting. The refrigerator's compressor should turn on. If you don't hear a fan turning inside, your thermostat or compressor may need to be replaced.
    Defrost Timer
    • The defrost timer regulates when the freezer and fridge will run its defrost cycle. If your fridge is not defrosting, or it is defrosting too often, this can affect its ability to freeze food. When in defrost mode, the freezer stops blowing cold air. Test the defrost timer by manually advancing the timer using a screwdriver inserted into the advancement pinion. Turn it clockwise for a 1/4 turn. This should force the timer to advance out of defrost in less than an hour. If it does not, you may have to replace the timer.
    Evaporator Coils
    • When the evaporator coils become frozen, your freezer will likely malfunction. If they are dirty or dusty, the same problem can occur. To defrost the coils inside, you can turn your freezer off for 24 to 48 hours then turn it back on. If it works properly, then the evaporator coils were frozen. Clean the coils located on the back of your fridge as well to ensure that dust and debris aren't affecting their efficiency.
    Wiring
    • The wiring outside and inside your fridge can be damaged by rodents or pets. Check the wiring outside your fridge for breaks. If there are none, you'll have to check all of the wiring. This is a long process requiring you to use a meter to test each connection. You may want to call an electrician to test the wiring to ensure that it is done properly.
    Environmental Factors
    • Once you've checked each component that runs your freezer and confirmed they are working correctly, consider that factors outside the freezer can affect its ability to freeze properly. The problem may be that the door is opened too often or for too long, allowing the cold air to escape and raising the temperature inside. Check the seal around your freezer door to ensure that it is getting a tight seal when closed and no gaps are allowing warm air inside. If you've added a significant amount of food all at once, this will increase the temperature inside and freezing can take several hours. If the vents are blocked by food items the movement of cold air is limited and will affect the freezer's temperature as well.
Hope this solution will help to solve your problem.
Good day! : )
Aug 30, 2011 | Kenmore Refrigerators
Freezer not freezing
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this would help you.
Have a nice day! : )
Aug 28, 2011 | Kenmore Refrigerators
Refrigerator & freezer not coolilng
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this will help you.
Aug 22, 2011 | Kenmore Refrigerators
Kenmore refrigerator 253.69962702 not cold. freezer frosting up.
  1. Power Supply
    Defrost Timer
    Evaporator Coils
    Wiring
Hope this tips will help you.
Have a good day! : )
Aug 20, 2011 | Refrigerators
Frig is about 20 years old been working good. now the refrigrator side is not cooling like it should.ive cleaned the bottom coils and around the compressor area at back. seems to be some ice accumulation...
Hey sounds like thermostat is no longer working (isn't regulating fridge's temperature), you can replace it yourself, all you need if fridge make and model number and order one from an appliance repair shop. Or have them do it. Either way it will probably cost more than the fridge is worth ($50 average for thermostat) to get it fixed...
May 22, 2011 | GE Refrigerators
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
141 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
