Question about Garden
I have a Toro Bushwacker, 51934B and need to change the primer bulb...cant' find a way to get the assembly apart?
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 16, 2009
How do i change the primer bulb on a toro model #ccr2450 snow blower
most primer bulbs are held in place by a metal ring plate with either 2 or 4 screws
remove the plate and the bulb will fall out
make sure that the molded edge of the new bulb is correctly fitted into the groove in the body and refit the plate and screws
Sep 06, 2015 | Toro Ccr Snowblower
Toro s-620 fuel primer button broke
any primer bulb will work if you install it between gas tank and carb in the fuel line
Jan 06, 2015 | Toro Garden
Where is the primer bulb o my toro lawnmower
Typically a primer is only used on 2 cycle engines not on lawnmower engines, so it would not have a primer bulb.
Jul 15, 2014 | Toro Garden
How to replace carb. Primer?
If you don't see two screws diagonal of each other than there is a little ring holding in your primer bulb. Be careful when removing ring as to not bend out of shape usually new primer bulbs don't come with them. If there are the two screws diagonally, than just unscrew and lift holding plate remove old primer and reverse for install... Good Luck....
Jun 20, 2014 | Toro Lawn Mower With Toro Power Tools
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
How do i replace the primer bulb in my personal pace toro mower
THERE ARE TWO TYPES ONE BEING A CLIP IN TYPE BULB ASSEMBLY THAT YOU SNAP OUT , PULL THE FUEL LINES OFF AND REPLACE . IT IS NOT HARD TO DO. SECOND IS YOU CAN REPLACE JUST THE BULB AND THERE SHOULD BE A REMOVABLE PLATE WITH FOUR SCREWS THAT SECURE THE BULB IN PLACE .WITH THIS ON THERE IS NO NEED TO DISCONNECT THE FUEL LINES . CHECK YOUR FUEL LINES IF IT THE ONE YOU REPALCE AS A ASSEMBLY ,THEY DRY OUT AFTER A PEROID OF TIME .
Jun 29, 2012 | Toro Personal Pace CARB Walk Power Mower
I took my toro 6.5 lawnmower carb apart and cleaned, now fuel spurts out of red tube into the air cleaner. Why is this happening?
Sounds like you assembled something wrong when reinstalling the carb. Or your missing a step or two.
Mar 18, 2012 | Toro Power Lawn Mower
I cant pay for answer. i have a toro upright.the primor button does not prime
check fuel lines for cracks or holes do the same with the primer bulb pretty common problems may need replaced
Jan 27, 2011 | Toro Lawn Mower With Toro Power Tools
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
Nov 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
