Question about Garden
How do i connect cleaning solution into the pressure washer so it washes and cleans at same time. I dont have the manual . thanks
  • 4 Answers
The pressure washer needs to come equipped with a chemical injection port (and tube), if it does not you may be able to buy the option from the equipment manufacturer or possible an aftermarket supplier.
Regards,
Paul Hill
CT Imaging
paul@ctimaging.com
www.ctimaging.com
Posted on May 30, 2011
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
How do I clean up the washer after a long time wash
Use the scalegon powder or white vineger 200 ml to clean the tub put tub clean program it will works auomatically, dont put clothes
Mar 01, 2015 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
Siemens WE61021GB/01 displays error code 03
http://teral.ru/katalog_stiral_nyh_mashin/siemens_simens/?p=6
best i can do is google translate
F03 is
Drain alarm (water in the tank is reduced to one level in the allotted time plot )
you ran out of time for the drum to fill
{too low pressure}
use the hot water valve as the cold
block off the hot water intake
this way you have a low pressure valve for cold
or
    1. There is a poor connection at terminals bilge pumps - seal the clamps, clean the terminals. 2. A malfunction in the bilge pump - clean the filter pump washing machine Siemens (Siemens) to either replace it. 3. There was a problem with the drain hose - hose to clean from pollution, eliminate the excesses, to restore the position of the drain hose specified in the instruction manual. 4. The pressure switch is faulty washing machine - repair of hydraulic water level sensor or replace the pressure switch.
Aug 11, 2014 | Siemens WE61021GB Front Load Washer
WASHED A TOLET PAPER ROLL, NOW MY WASHER OVERFLOWS? THIS HAPPENED BEFORE AND HAD SOMEONE COME OUT AND MY EX HUSBAND KNOW HOW TO CLEAN IT OUT BUT I DONT CAN YOU HELP??? THANK YOU!
Overflowing due to blockage at the pressure hose or pressure tube you need to locate the chamber and clean it out, Make and model please
May 03, 2011 | Washing Machines
We bought samsunf fully automatic but we dont have adequate water supply so how to use it by adding water manually
check to make sure the filter at the connection where the hose goes into the washer is clear of debris. this can cause low water pressure if it's clogged. it's real simple to fix. just disconnect the hose from the washer and remove screen from inside the hole and clean it off and replace. Notsure if you can run the machine mannually by adding water.
Aug 11, 2010 | Samsung Washing Machines
Nf is showing on the screen ans washer stops
Here is a note from the service manual:
NOTE: The machine control board will attempt to fill the washer and satisfy the pressure switch during an acumulated period of 6 - 8 minutes. If the time exceeds this time frame, the unit WILL shut down.
Having said that... First thing
1. Turn off the water at the wall connection
2. Remove the water hoses
3. Remove and clean the screens inside the water inlet valve
4. Check hoses for obstructions on EACH fitting.
5. Reinstall hoses
6. Turn on water supply at the wall connection.
7. Test machine.
The above need for cleaning happens more often than you would think.
If this does not get you going normally again just respond here and we can continue troubleshooting.
Kelly
Apr 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
Jul 20, 2009 | Garden
Samsung B1245 front loader
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Mar 15, 2009 | Samsung B1245 Front Load Washer
Kenmore HE3t washer not working properly
ok lets see here im onthejob,,i take it that cycle stops with suds..ok first are we using he or low sudsing detergent,,,next when you clean pump filter did you check pump wires for defectives,,,try and bleach unit out to get rid of slugg...also check connection to pressure switch,,and ccu...keep me posted..onthejob
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
