Question about Shinco SDP-2001 Portable DVD Player
When i put a DVD into the DVD player, it does not play. the DVD does not even spin in the player
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
Feb 03, 2010 | Panasonic DVD-S25
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Problems to play any dvd at my DVP-NS575P
sir,,,your appliance needs maintenance,,,,u need to clean your dvd player especially its lens but be careful you might destroy it,,,use ligther fluid or any in cleaning liquid materials but it should evaporate fast,,,,thnkss and hope to help you thnksssssss,,!!
Jan 29, 2008 | Sony DVP-NS300 DVD Player
Dvd player not working
buy new one then replace it with the old one and take it back for refund
Oct 30, 2007 | Durabrand DVD-1002 DVD Player
Portable dvd player
Try out another DVD. Problem might be in your DVD.
Sep 22, 2007 | LG KU990 Viewty
Kawasaki portable dual screen DVD Player
i need a scimatic - wiring diagram for model #PVS1965S.
vancechristy@hotmail.com
May 31, 2007 | kawasaki PVS297OS
Shinco SDP-2001 Portable DVD Player Logo
Top Shinco Televison & Video Experts
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Shinco Televison and Video Expert? Answer questions, earn points and help others
