Question about Zenith Televison & Video
The bulb for my lcd e44w46lcd tv has went out 4 times in the past 5 years i am very disappointed in this tv can u tell me why the bulb goes out so often
  • 104 Answers
It could be thru the power surges that you must be having but not noticeable.
Usually the bulb goes out because the power supply is not constant so when there's a surge this is what happens to electrical/electronic equipments.
G.
Posted on May 30, 2011
Zenith E44W46LCD TV power/operation indicator lamp blinks green then goes red when power switch pressed. I can hear the fan motor but no picture. No history of lamp indicator warning.
If the tv projection lamp already been inside the tv now like a 1 1/2 or 2 years?Tv used it every day like 4 or 5 hrs every days?Yes?Than it is the tv projection lamp have to be replace,because the tv projection lamp life span have ended.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
My set powers up with volume but no picture
When was the last time u replaced the projection bulb in this tv?If this tv have the bulb in side been use like 1 or 1 1/2 years and turn on like 4 or 5 hours a day?The bulb life span is over,require a new bulb for the replacement.
Jun 17, 2010 | Zenith E44W46LCD 44" Rear Projection...
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
BRIGTHNESS TO LOW
Light in wrong, however I wouldn't waste the money on this unit. Light engine will fail in 3 to 4 years and show a yellow spot at first.
(ie past post)
TV Tech
Jun 28, 2008 | Zenith E44W46LCD 44" Rear Projection...
TV does not respond to Remote
follow wire from sensor inside tv to tuner board and resolder.
Apr 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
E44W46LCD
Light engine needs to be replaced. Cost of it at an authorized dealer: $800. Best known deal around: $199 at matelectronics.com
Nov 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith TV E44W46LCD Picture Problem
The PIP module is bad or the video processor circuit. Most likely a main board replacement will be neccasary. Good Luck
Mar 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
