Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Doesn;t spray solution - Bissell 8910 ProHeat Clear View Upright Vacuum
  • 23 Answers
Pump is bad
Posted on May 30, 2011
Best way to clean a laminate "wood" floor. I use Pine Sol and lately have been noticing streak marks and dullness.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
May 19, 2017 | Vacuums
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
I recently moved into a new house that has central vacuum -- a Broan V40C-3. I noticed that suction is low, and figured that I just needed to empty the canister in the basement. However, even though I...
It's probably just sticking, they come off from base. get some wd40 spray around connection, let sit for a few and wiggle back and forth lightly, you and one other person should try twisting too
Jul 09, 2011 | Broan-NuTone Vacuums
Bissell 7901-1 Cable that turns brush ripped. Where can I get a new one and how do I replace. Also when I turn to the high trafficsetting fluid doesn't spray out but it does on water only. Spinny...
If I'm understanding your question concerning cable/belt ,you can go to a bissel parts supplyer on line and order what you need ther are two bels that are envolved inthat area. The one that turs the brush is the belt with the teeth/cogs on it. To replace it there is an accesess door on the right hand side,using a screwdriver gently pry up on the door,which will expose the belt area .The belt that you are replaceing will attach on the brush then strech it to the point of the motor shaft, since one belt remains it's a simple prosses of elimination.the rest of your question is some what envolved I've requested info about the same area. So you might want to keep a look out for the answer tohow realign smartmix valve
Hope this helps.
Jun 17, 2011 | Bissell 7901-1 ProHeat Scotchgard Upright...
The cord will not rewind
These get stuck all the time...I own 2 of these , and I have done this many times...Get a can of WD40 or some type of spray lubricant with the little straw in the nozzle. Try pulling and pushing the cord back inside(don't pull it too hard) while you are spraying the lubricant directly inside where the cord comes out. push the cord back in as if you were going to force all of it back inside the cord winder. You may even have to bump the back of the machine where the cord winder is located. But it will wind back up.If you are worried about getting the lubricant on something that it doesn't need to be on , then take the Vac apart and spray it directly on the the coils of the cord winder..A lot of times, that's all they do in the repair shop when they tell you they replaced the cord winder....
Jun 15, 2011 | Electrolux Epic 6500 Vacuum
How do you work it?
below is a website to retreive a free manual for yours. have the model number ready so you can find it much easier....
bye.
http://homeappliance.manualsonline.com/manuals/mfg/bissell/bissell_vacuum_cleaner_product_list.html
Feb 07, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
19 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
