Question about Sharp MX-2300N Color Copier
Norway. MX-2300N. Yellow colour across the upper part of the print out. How to solve the problem?
  • 1 more comment
  • tbs0 May 30, 2011
    Thanks for your answer. 1-6 tried. Must be somthing else. How to check the tranfer roller or the drum? How to repair or replace the unit? Easy to do it myself or do I need a spesialist?
    Thanks a lot
  • tbs0 May 30, 2011
    A drum and/or a transfer roller has a lifetime. How to check? How to check if this problem is caused by the roller or drum. I need to repair it myself. Please advise.
  • tbs0 May 30, 2011
    What does code F1-11 mean?
    The yellow colour come and goes.
    Total out BW/Col 156 005 / 107 793
    DOC Fil (COL)/(2COL) Maintance all 58 138 / 55 969
    TC1/TC2 Belt 58138 740/740
    TC1 Belt range 4 162 562 Fuser unit 108 708
    TC1 Belt day 441 / 740 Fuser Acum day 740 / 740
    TC2 Belt 275 065 Drum life (K) 052
    TC2 Belt range 18 604 012 / Drum life (C) 056
    Drumlife (M) 042 Devel life (Y) 042
    Drum life (K) 057
    Deve life (K)/(C)/(M) 052 / 042 / 042
    The info above is from the printer display
    Is it possible to give me info what to replace. Drum, fuser unit, tranfer roller og developer?
    Thanks so much
  • Sharp Master
  • 11,800 Answers
This is caused by a failure of either the drum or the transfer roller - they are either dirty or their life expectancy is very close to the end. You can press #*C* respectively, then press 22 start 1 start respectively then it will show you all the counters including drum and developer for the 4 colors - if they are close to their rated life (100,000 (black) / 60,000 (color) average pages) you should replace them.
It would help if you would also buy the full service manual for your printer , it costs $14
http://www.tradebit.com/filedetail.php/110098542-sharp-mx-2300g-mx-2700g-mx-2300n-mx-2700n-service-manual
Posted on May 30, 2011
  • Azrael SRL May 30, 2011
    F1-11 - finisher bundle process motor malfunction = the motor that powers the bundle mechanism has encountered an abnormal resistance and stopped. You will need to open the bundle mechanism to investigate the origin of the fault, the service manual is mandatory for that.
    There is an inconsistency between the use data and units life counter: the use data shows BW/Col > 156,005/107,793 which is well beyond the recommended life estimates > 100,000/60,000 , but the life counter shows values well below that - 0xx is the part from 100 of life used - on all around half. If the drum, fuser and developer were replaced at the correct times then the data's match, if not then the life counters were reseted without the actual parts being replaced - they must be all replaced immediately.
    Genius:
  • 1,157 Answers
Hi tbs0,
Have you tried cleaning the corona's? If not, please follow the steps below.
1. Please open the front door/cover.
2. Press the green button located in the center upper.
3. You will now see the waste toner collector, please remove it.
4. Look for the cleaning rods, four green knobs small diameter.
5. Now pull them out about a foot and they will stop. Push them back in for four or five times each color.
6. Look for a wand on the door. The wand fits the pad down in the slot below the green rods. Slide it in and out to clean the laser.
If this procedure does not work you have problems with your drums or transfer rollers.
Hope this helps.
Thank you for using FixYa.
  • Reynaldo Labaguis Jr.
    Reynaldo Labaguis Jr. May 30, 2011
    Hi tbs0,
    Since you've already tried the basic troubleshooting, I highly recommend to consult an authorized repairman to prevent further damage on the unit.
    Hope it helps.
A LOUD NOISE WHEN I TURN ON MY COPIER SHARP MX-2300N AND IT CAN NOT COPY OR PRINT
Hi Patience .
Have you got anything on the display ?
Any error codes ?
Jun 27, 2016 | Sharp Office Equipment & Supplies
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
How to find copy counter for mono and colour on Sharp mx2300n
Press and hold the button marked "Copy". Alternatively, press "System Settings", then "Total Count", then "Job Count" and now you have the option to both view and print the readings.
Jan 16, 2014 | Sharp MX-2300N Color Copier
It doesn't print in coulor
Please re fill the colour cartridge,,,,!!!!
Jul 26, 2011 | Sharp MX-2300N Color Copier
MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
May 18, 2010 | Sharp MX-2300N Color Copier
Our printer is printing horizontal lines across
open the front door and press the green button in the center upper ,remove the waste toner collector ( carefully it will spill if turned over ) you will see four green knobs small diameter these are cleaning rods ..pull them out about a foot they will stop push them back in four or five times each color there is also a wand on the door and it fits pad down in the slot below the green rods slide it in and out to clean the laser....if this does not do the trick you will need service refr to you manual for cleaning if you have it
Feb 16, 2010 | Sharp MX-2300N Color Copier
How to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Dec 14, 2009 | Sharp MX-2300N Color Copier
Network printing from a mac computer to sharp mx 2300n printer
HI,
Sounds like driver problem..
go to this site: Driver Update and make required updates.
wish you best of luck
cheers
Dec 17, 2008 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
115 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
