Question about Seagate Barracuda 7200.11 160 GB SATA II Hard Drive
Seagate Barracuda 7200.11 160 GB HDD - Seagate Barracuda 7200.11 160 GB SATA II Hard Drive
  • Seagate Master
  • 27,725 Answers
If you are having problems
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
hope this helps
Posted on May 30, 2011
Seagate pipeline hdd 500 gb. can I remove it from a lorex dvr, and put it in my pc?
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
Sep 21, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
I have a seagate barracuda 7200.12, 500 GB, HDD, as suddenly it is not working nothing is showing up, some type of clicking sound is also coming from it. the computer detects the hdd, but nothing is...
If you have another computer, you could try to plug it in there as a slave/secondary drive so that you can try to see if My Computer would still recognize it. If it works, then great, you can still do backups. If not, and you really need that data, you might want to get the services of a data recovery company.
Jul 29, 2011 | Seagate Barracuda 7200.10 500 GB SATA Hard...
What kind of external enclosure do I need for a Seagate Barracuda 7200.9 hard drive?
You need something like this one
http://www.scan.co.uk/Products/Newlink-35-CDLSB-806-Aluminium-SATA-HDD-To-USB-20-Enclousure
Aug 22, 2010 | Seagate Barracuda 7200.9 300 GB SATA Hard...
I have a problem .i.e my seagate barracuda 160gb HDD is not detecting in bios .it is a new HDD
Its a master/slave problem. Put it to cable select mode
http://www-307.ibm.com/pc/support/site.wss/42470_hdd4.gif
Put the jumper to CS then reboot.
Nov 14, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Downgrade of Firmware
Firmware updates and downgrades may only be obtained by contacting Seagate Support Directly.
If you have been referred to Seagate by a different vendor who has told you that you need a firmware update, please contact Seagate Support for more information and confirmation.
http://www.seagate.com/www/en-us/about/contact_us
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 200 GB 7200 RPM
can you take a snapshot from the smart page?
Feb 22, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Seagate Barracuda 7200.11 160 GB SATA II Hard Drive Logo
59 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
