Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
What does the flashing F1 mean? - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • Whirlpool Master
  • 1,902 Answers
Hello & Welcome to FixYa
F1 error in your whirlpool cabrio indicates bad control and should be replaced to resolve the error code. However, you can contact Whirlpool as well prior to replacing the control yourself as I have seen whirlpool paying for the parts themselves just because this is known to be a common issue. Please get back to me if you have any other questions.
Kevin
Posted on May 30, 2011
What does f1 mean when it flashes where the temp guage is?
It means you have a problem with the fuel injection system if you can start the bike then take it to a Suzuki mechanic. If the F1 is full on i.e.not flashing then the bike will not start normally. You still have a fuel system problem but now you have to find a way of getting it to a Suzuki mechanic. You should have a red light showing near the neutral indicator light.
Jul 14, 2014 | 2004 Suzuki GSX-R 600
F1 on screen
F1 means the control (EOC) has failed. Try leaving the power off to the range for as long as possible (overnight). If the problem persists the EOC would need to be replaced. This part can cost over $300.
Apr 18, 2014 | Kenmore Kitchen Ranges
What is code F1 mean on the Whilrpool Cabrio. The washer stops about 5 seconds when I first put it on.
Ok the Cabrios have alot of problems. In your owners manual there is a big page where it gives you errors codes and what to do it also givees you a diagnostic feature which helps determine the problem. This site gives you the fault codes and what to replace. F1 means primary control failure. Also sometimes when the control board is bad something else could also be wrong. Good Luck
F1 (F60-68)
Primary Control Failure F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
See Accessing & Removing the Electronic Assemblies. F1 (F60-68)
See Accessing & Removing the Electronic Assemblies.http://www.advantagesupplyfl.com/WhirlpoolCabrioWasherFaultCodes.html
Jun 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio top load washer. When I load the clothes and start the washer and it begins to run I hear an alarm, it stops and a F1 flashes on the display. What does this mean?
F1 (F60-68)
F1 flashing on the display indicates a primary control failure.
"F then 1 flashes when there is a primary control failure. Replace the machine control assembly."
The link below lists Cabrio failre codes.
Dec 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the problem when F1 flashes
This will depend on whether F1 is flashing on both drawers or just one (which one).
F1 flashing in both drawers means there is water at the base of the housing which had triggered the flood switch. you will have to get the bottom drawer out and dry the base with towels and hair dryer. Make sure the power is turned off. Need to find the cause of the water leak. Could be drawer seal, broken hose or too much foam in detergent.
If F1 is coming in one drawer and the other drawer has blank display. The power is lost to the drawer with blank display. Could be thermal fuse blown or problem with power board at the base.
Hope this helps.
Nov 13, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
F1 keeps flashing and beeping
you can google your oven model for its codes. on our maytag oven the F1 code means defective touch pad or control board.
Jun 21, 2010 | GE Profile JT952 Electric Double Oven
What does f1 mean and can it be fixed?
F1 means Primary Control Failure.F then 1 flashes when there is a
primary control failure.Replace the machine control assembly and
see accessing and removing the Electronic Assemblies.
Apr 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 appears both drawers are flashing and beeping can't turn off power (it turns off for a moment and then turn itself back on with F1 code, beeping and flashing) Unplugged it hoping it would reset, it did...
F1 means that the flood sensor has been tripped. Remove the bottom draw and dry the water out. Mop the majority out and use a hair dryer to get it all nice and dry. This should clear the f1. There may be underlying issues of why the unit has leaked but see how you get on.
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 keeping flashing up
F1 Indicated the electronic control board has failed.
Jun 12, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
