Question about Linksys Wireless-G Broadband Router
Start up error 321 ethernet cable does not appear to be connected properly. I've checked and rechecked connection is good, green lights on router. I have sympatico, is this the problem?
  • amorina Sep 27, 2008
    i have the problem fixing my ethernet connection. everything is connected but the problem is still existing. I follow all the steps provided by the user guide handouts. The problem goes like this....YOUR ENTHERNET CONNECTION DOES NOT APPEAR CONNECTED PROPERLY...Thanks for helping me....Amor
  • meet2sagar Oct 11, 2008
    After connecting the Linksys WRT54G2 router to the modem and PC as per the instruction, I am getting the Error 321: Your ethernat cable may not be connected to computer port. Please check.
    I checked and found everything is fine. But still getting this message repeatedly.
    Scholar:
  • 136 Answers
First, see if your firewall is not blocking the connection.
If it is, add the connection as a "safe" or "authorized". It depends on the software.
Also, check if your IP address is set properly.
Posted on Oct 11, 2008
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
Red light on modem's internet
I think incorrect physical connection between your router device and the PC.Because cable modem status light should be solid green.it indicates that your ADSL/cable modem has a good connection.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 27, 2012 | Computers & Internet
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
there is a program on your computer that shouldnt be there thats preventing it from working..go to start then control panel then clink on maintenance+system then click on device manager and any program in the list in yellow triangles you uninstall.
Linksys WRT160N will not finish installing. On the 4th step it says your ethernet cable does not appear to be connected properly. Error 321. I don't really think its the ethernet cables because i tried 2...
error 321 or 322shows that the cable is not connected to the router and the computer.
That is actually a bug in the CD. Even if the cable is connected it shows that it is not connected.
You can set up the router manually, without the CD.
Click Here for step by step solution
Nov 03, 2009 | Linksys WRT160N Wireless Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
321 error
try this power of both pc and router , unplug router power on pc then power on router see if it then picks up the isp, if not just simply unpup router and plug it back in while pc is running hope this helps!!!! good luck
Mar 23, 2009 | Linksys WRT54G2 Wireless Router
My dell computer suddenly is not connecting to the internet and is showing "network cable unplugged" error
  1. start the troubleshooting process by making sure that everything (routers,switches, hubs, modems, and computers) is firmlyplugged in.
  2. If your computer is on and the other end of the Ethernet cable isconnected to a network device, the link or activity LED should light.If the light remains dark after you plug in the cable, replace thecable. If replacing the cable gives the same result (no green light), then go to the next step.
  3. Once you’ve eliminated cabling as a source of the problem, it’s time tolook to your computer. Start by making sure that your computer is able toaccess your Ethernet card. A good tool for doing this, and subsequentnetwork troubleshooting, is the command prompt.
  4. Select Start, All Programs, Accessories, and then Command Prompt. When the Command Prompt window opens, type ipconfig –alland press ENTER. Various lines of information will display, dependingon how your system is configured. Look for a section labeled EthernetAdapter Local Area Connection. This section should include a linelabeled Description, which should be a description of your Ethernetcard. If you see it, then your computer knows about your Ethernet cardand has successfully loaded the necessary drivers. If the Descriptionline is blank or missing, you will need to reinstall the drivers foryour Ethernet card.
  5. Your Ethernet card doesn’t detect a connection to the Ethernet cable. Open a command prompt, type ipconfig –all,and press ENTER. If the section that starts with Ethernet adapter LocalArea Connection contains a line labeled Media, with a status of MediaDisconnected, then your computer is unable to detect that a link hasbeen made from your Ethernet card through the Ethernet cable to anothernetwork device, such as your computer or router. Recheck the cabling.Use a known good cable to connect your computer to a known good networkdevice and then perform the check again. If the status is still MediaDisconnected, and you are sure that the cable and the network devicethe cable connects to are good, then you may have a bad Ethernet card.Reinstall the Ethernet card. If the problem continues, you may need toreplace the card.
  6. Other things to check:
  7. Bad connection, bad cable, or wrong cable. The ports on arouter, hub, switch, wireless access point, and print server can, likeany other device, go bad. However, the most common problem is not a badport but a bad or loose connection, a bad Ethernet cable, or the wrongtype of cable. Refer to the Cabling section above, to eliminate thesepossibilities.
  8. Wrong port. One possible cause of Ethernet port problems isusing the wrong port on a network device. For example, routers have WAN(wide-area network) and LAN ports. These ports accept the same Ethernetcabling but are not interchangeable. The same is true of hubs andswitches that have uplink ports, which are specially wired LAN portsthat allow easy cascading of multiple hubs and switches. In some cases,the uplink port is also a normal LAN port controlled by a switch on thedevice. If you’re using the uplink port as a normal LAN port, make surethe device is configured properly for this type of use.
    If aport doesn’t appear to be working, you can use the link light toconfirm it. Port link lights should always be lit when a good cable isconnected between the port and another working network device. If youuse known good cable and a known good network device to test the portbut the link light isn’t lit, you may have a bad port. You can eitherreplace the network device, or in the case of a hub/switch, add a hubor switch to gain more LAN ports.
  9. You cannot connect to other computers or router/Internet. Whenother computers in your LAN can connect to each other, as well as tothe Internet or other services, and your computer cannot, this may bean indication that your computer did not receive an IP (InternetProtocol) assignment when you booted.
  10. Open a command prompt, type ipconfig –all, and press ENTER. Inthe section labeled Ethernet adapter Local Area Connection, look forthe line labeled IP. If it starts with 169, you have a self-assignedIP, which indicates that your computer was not able to acquire an IPassignment from the DHCP (Dynamic Host Configuration Protocol) server.
    Test your access to the DHCP server by using the ping command. Open a command prompt and type pingfollowed by the IP address of the DHCP server. Your DHCP server isprobably the same as your router. For example, if your router’s IP is192.168.1.1, then type ping 192.168.1.1 and press ENTER. Youshould see four lines of text, starting with Reply From 192.168.1.1:Bytes 32, followed by time values that indicate how much time elapsedbetween the ping command and the router’s response. If you see fourlines that say Request Timed Out, then your computer cannot reach yourrouter/DHCP server.
    Make sure the router is plugged in,turned on, and properly configured to provide DHCP services.
These are just a few things to try to help figure out if it is your cable, ethernet card, router, or some other problem.
Jan 19, 2009 | Dell Ethernet Card Network Adapter
Still not connected
vhevk your ethernet cable wire.
if u connect router to swithc then use straight cable.
if u use router to computer use cross cable.
Jan 10, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
