Question about JVC RX-6018V Receiver
When the reciever is powered on it flashes overload what does that mean?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on May 29, 2011
I have a Karcher electric power washer. The circuit breaker only works for less than one minute. I have to press the reset again and again. Please help. Thanks.
do you mean the gfci that is normally at the end of the cord or the switch on the unit itself. if its the ground fault circuit interrupter its detecting a short to ground and protecting you from recieving a shock.must inspect inside unit for possible moisture around motor or switch i don't think its overloading
Aug 08, 2013 | Karcher K2.26 Electric Power Washer
Overload
that means you are trying to pull way to much power from the receiver and it can not supply the power needed
Jul 16, 2013 | Panasonic SA-HE200 Receiver
Display shows overload and receiver shuts down
This means that one (or maybe more) of the amplifiers is shorted. Remove all speakers cables and try again. If you get the same message that means that one (or more) amplifiers is fried. To find which and why you will have to open the unit and test the amplifiers.
Jul 31, 2010 | Pioneer VSX-D412 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Overload on home theatre reciever
It would mean one of the power modules died. I believe they are STK412-530. Not an easy repair for a DIY.
Good luck
May 23, 2009 | JBL PP-600II System
I have a phase linear uv7i and i cannot get it to power up. i have all wires hooked upand i get the power light to flash a couple of times and it beeps when i touch the power button but the display w
ok does power just flash or is it steady. flashing usually means your overloading it somehow and then it just wont play prob because circuitry protection. Ok and what do you mean anything else what else do you have and how do you have it hooked up and to what and what ohms at and what is your amp stable at. What type of subs.
May 12, 2009 | Car Audio & Video
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
On screen says overload
yaa! my reciever does that too!! whats the problem?
Mar 16, 2008 | JVC RX-5030/32 Receiver
JVC RX-6018V Receiver Logo
55 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
