Question about Dishwashers
When I try to drain my dishwasher, it fills up my sink. when the sink drains, my dishwasher fills
    Sergeant:
    Champion:
  • 257 Answers
Sounds like you have your dishwasher drain connected directly to your drain under sink and you have a blocked drain. It will function normally once you have removed the block in the sink drain but you should have a the dishwasher drain hose hooked up to a air gap to prevent harmful bacteria from getting in to the dishwasher again in the future. Hope this helps.
Posted on May 29, 2011
SOURCE: bosch dishwasher SHX46 won't fill with water
My model is actually a SHX46 but I was able to piece together some advice off of this site. This is what I did. I removed the toe plate and then I soaked up all the water that I could out of the white pan at the bottom. Then I unhooked the water supply line so that I could pull the dishwasher out. Once I got it out, I tipped it forward to drain out the rest of the water. I then unhooked the drain line that was connected to the disposal and cleaned it out with a "Snake line" I then hooked everything back up and it worked. Thanks so much for this website, I know it saved me a ton of $$$$$$$$$.
Posted on Jan 29, 2009
  • 11 Answers
SOURCE: Stopping the Cancel/Drain Cycle
Disconnect the Drain Hose from the plumbing under the sink and using a bucket hold the hose in the bucket and attempt to drain the dishwasher. If you have a disposal and recently replaced it, the knockout plug may be still inside where the drain hose attaches into the disposal. To determine if it is still there, using a screwdriver, stick the screwdriver into the drain hose hole on the side of the disposer and if you feel blockage then the knockout plug is still in the disposer and will need to come out. To remove the plug use a short screwdriver and a hammer and place the screwdriver into the drain and strike the top of the screwdriver once and the plug should pop out of the disposal. Be careful not to hit the disposal too hard or to damage any plumbing. Reattach the drain hose and you should be all set. When you remove the drain hose if the machine is flashing an error code, go to the circuit breaker box and turn off the breaker for the dishwasher, wait 5 mins and turn it back on. This should reset the board and the machine should operate properly.
Posted on Feb 05, 2009
aborcass
  • 2651 Answers
SOURCE: it all started when garbage disposal went out. dishwasher filled
no but keeping hte screens anddrains clear will, no real majic answer here ohter then taking apart and lookin for the blockage
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Dishwasher does not drain, instead drains through overflow valve in sink. No apparent clog seen.
Usually the sink connection is not an overflow, it is the main drain from the dishwasher. It is more likely your s-bend is blocked under the sink- try putting a bucket under it and unscrewing the u-shaped piece and cleaning out (remember don't wash it in that sink while the pipe is off)
Posted on Apr 27, 2009
Maytag317
  • 1136 Answers
SOURCE: after washing dishes in the kitchen sink, water
Hi, There is a drain hose under the sink that goes to the dishwasher. Make sure that hose is raised up higher then the drain pipe for you sink. It is just draining into the dishwasher because the drain hose is to low.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 10, 2009
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux dishwasher overflows
Aug 09, 2012 | Dishwashers
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. ...now it...
hi,
the unit will not fill with water until it will drain as it needs to complete the drain function before it can move onto the next step.
make sure the non return valve under the filter is properly fitted in the sump of the unit. then check the drain spigot under the sink where the drain hose connects to the sink u bend. This is the most common causes of a blocked drain.
Nov 28, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Dishwashers Logo
196 people viewed this question
Top Dishwashers Experts
