Question about Kenmore Elite HE4 Electric Dryer
Black stains on white table cloth
My kenmore elite calypso leaves black stains on white items. Service person replaced seal at top of machine . Problem not fixed.
  • topjdog Aug 25, 2008
    this machine has never used fabric softeners and always used low sudsing soap. machine does not have a cleaning cycle
  • Anonymous Dec 29, 2008
    Kenmore Elite EH54 Dryer leaves one inch long brown lines on whites.
    Scholar:
  • 121 Answers
Hi! topjdog
I hope you have been running the monthly cleaning cycle. This includes cleaning the front gasket.
InMrFixIt
Posted on Aug 22, 2008
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Black grease stains on clothes
trasmission top seal is bad
oil out means water in
Jun 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite dryer burn marks on cloths
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite calypso 21086 leaves dirt streaks on clothes
Run the hottest & fullest cycle possible - without a load - and add a grease remover - like goo-gone. Fatty tissues build up inside the tub - and can be released on hot cycles if HOT wasn't used very often.
It is recommended to run a HOT load every 2 weeks or so to avoid these buildups and staining of clothes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 21086
Whirlpool calypso GVW9959Q - Black stains on whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 14, 2008 | Washing Machines
Black Stains on my whites
discoloration.
RESOLUTION:
Feb 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ruining cloths, leaves black stain.
Black stains could only come from rubber part that is deteriorating. Need to check all hoses, rubber boot and at bearing seal.
Dec 11, 2007 | GE WCVH6260F Front Load Washer
Clothes getting sucked under agitator
I was able to find information on another web site with a Whirlpool Calypso repair manual: https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Check out steps 5 and 6 on page 36:
6. Using two (2) flat bladed screwdrivers, 90°
apart, in the notches provided, separate the
dome from the outer wash plate. (Fig. 3-11)
7. Remove the six (6) 3/8” bolts securing the
outer wash plate to the universal joint.
(Fig. 3-12) Remove the outer wash plate
from the basket.
That gave me enough room to lift the outer wash plate and remove three napkins and a wash rag.
P.S. Take precautions to keep the bolts from dropping under the outer wash plate.
Dec 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Kenmore Elite HE4 Electric Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
