Question about Astro Professional Firestone RideRite Air Helper Springs Rear 19851998 Chevrolet BASE 2029 Telescope
How do you remove the rear air bags on a 2001 lincoln navigator, and replace them with springs
  • 3,186 Answers
You posted this question in the Telescope Forum.
Posted on May 30, 2011
Air bag pump is running, new airbags . rear bags wont air up.
These Lincoln air suspensions are terrible. I have converted many over to coil springs at a fraction of the cost of replacing/repairing the bags. If the rear bags don't inflate, there is a broken air line to the bags or the bags are leaking
Apr 12, 2015 | 2001 Lincoln Navigator
What size coil springs for 2001 lincoln navigator rear supension
That is not a question you ask on the internet,
& no one has any diagrams, unless they own the
same vehicle & have purchased factory manuals
You ask a dealer by giving the parts dept your
VIN #
If your converting from air to conventional suspension,
then you ask the parts suppliers that sell the new parts
your going to use to replace the air shocks/struts
Jan 18, 2013 | 2001 Lincoln Navigator
How do you keep rear air bags inflated
I replace both rear air springs on my envoy denali and it it still wornt inflate all the way up and u could hear the compressor working what can I do to fix the problem
Sep 30, 2012 | 2000 Lincoln Navigator
I have a 2001 lincoln navigator the rear suspension is down i hear the pump come on but it will not raise by the way i had the pump replace about 8 months ago what could be the problem and can i fix i
The air bags commonly go bad on these trucks as well as the Expeditions. They are called Air Springs. I sell better quality ones than those sold at auto part stores and they are also a bit cheaper than dealer parts. But either way the problem is you have bad air springs.
Jul 18, 2012 | 2001 Lincoln Navigator
Air suspension not functioning back of truck sitting on wheels
Problem most likely 1 of 2 things.
  1. Most common is bad air springs- they will fill up but fail to hold air. 1 symptom is you will hear the air compressor constantly pumping air to try to keep the spring inflated
  2. Bad line from compressor to the air spring- this is less likely since it shouldn't impact the air spring's ability to hold the air once it's pumped up.
If the rear of the truck raises and settles back on the wheels after you turn the truck off then it's almost certain to be the air springs. Often referred to as air bags, they look like normal springs with the air bags inside.
If the rear of the truck doesn't raise at all, the line from the compressor is likely bad to the point that it won't fill the springs at all. If it turns out to be the springs, you should replace them in pairs since they often will go within months of each other. Another thing to consider is some Lincoln owners have opted to replace the air ride system with conventional springs.
Sep 04, 2011 | 1998 Lincoln Navigator
2001 Navigator rear suspension sagging. While
It sounds like one of your air bags could have blown. I would check them first. I would also suggest checking into a replacement non air conversion kit from Strutmasters. I replaced the air system on my 2002 Navigator and saved a lot of time, money and headaches.The lines on my navigator had holes in them and I replaced the compressor twice before I realized it. Very costly. Avoid all the hassle and check out Strutmasters.
May 24, 2010 | 2001 Lincoln Navigator
How do i release the air in the bags on a 2003 lincoln navigator 2 wheel drive
First thing is why would you want to and then next is make sure the air ride is turned off. At the top of the air springs there a valve you will have to removed the line off of the valve and then remove the valve from the air springs, then you can remove it. Hope this helps
Mar 05, 2010 | 2004 Lincoln Navigator
2001 Lincoln Navigator Air Suspension
the auto leveling is standard on the navigator.
first you have to understan that the auto leveling system is on front and rear of these trucks.
one way to tell is do you hear the pump running and do you have air in the front bags. and if you do you need a rear level sensor.
later paul
Dec 31, 2008 | 2001 Lincoln Navigator
you can replace the bags. with springs from a navigator that did not come with air ride. a salvage yard should help you out. good luck
Nov 23, 2008 | 2000 Lincoln Navigator
Rear suspension
i have a 99 lincoln town car and the rear air ride don't work the back of the car is hitting the ground how do i fix that
Oct 11, 2008 | 1999 Lincoln Town Car
Astro Professional Firestone RideRite Air Helper Springs  Rear 19851998 Chevrolet  BASE 2029 Telescope Logo
207 people viewed this question
Top Astro Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Astro Optic Expert? Answer questions, earn points and help others
