Question about Weber SPIRIT E-210 (NG)
My 2 year old weber E-210 gas grill does light. I replaced the igniter, but I do not hear any propane gas being sent to the .I have also tried to manullay light it with a match, and nothing. HELP!
    Sergeant:
  • 207 Answers
If you have recently bought a new propane tank you may have gotten a bad one. Try taking it back to the store and asking for an exchange. The valves go bad inside the tanks sometimes.
Posted on Jun 06, 2011
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
All of the sudden my grill will only heat up to around 350 degrees. It is about a year old and has worked flawlessly up till now. It lights and the flames seem to be coming out of all burners but just...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 03, 2010 | Weber SPIRIT E-210 (NG)
Gas is barely flowing-used to hear hiss before I lit. Tried replacing pressure valve and got a new tank of gas. Also disassembled manifold and cleaned out all burners.
I had the same problem years ago with an old charbroil and ended up fixing by replacing the threaded female gas connector on the regulator with one of the old style male inside threaded type. This is the connector that connects the hose/regulator to the propane tank.
Aug 20, 2010 | Weber Genesis Silver C Grill
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
My grill won't light, and I don't hear gas running
sounds like a problem with tank valve. Try attaching back to grill. Open valve slowly, if you open to fast valve thinks it is leaking and shuts down. If this doesnt work try a differant tank, buy always open slowly.
Jun 12, 2009 | Weber Genesis Silver B Grill
Our grill does not lite. There is propane. Could it be the gas regulator?If so how do we test and fix it?
There are several possible problems, but I would start with the basics. I know this sounds silly, but is the gas at the tank turned on?
OK - assuming its not that easy, clean out the burner tubes to make sure spider webs or other obstructions are removed. Re-assemble and try again.
If it still doesn't lite, try manually lighting it with a lighter or match. If it lights fine that way, its likely your cross-over ignition and you can just replace it
Go to the Weber site and download your manual. It will have further trouble-shooting procedures, as well as the correct part numbers you will need for your grill. http://weber.com/help/manuals.aspx
May 20, 2009 | Weber Genesis Silver C Grill
Weber SPIRIT E-210 (NG) Logo
271 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
