Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
When I engage the mower blades it makes a nasty noise, like a bad bearing. I checked the brakes, belts, etc and all is well. Any thoughts?
  • 252 Answers
Hi there mrswp211
check out the pulleys from the pto to the deck for noise - if rumbly / noisy replace them , if not
remove pto to deck belt ( make note of belt routing 1st ) then rotate blades and spindles by hand give a good spin you should hear if noisy , grab blades and try to move them fore/ aft to see have movement if they do and they are not smooth and quite spindle bearings are the problem
generally if unit is noisy only when deck engaged bearings will cause this
but make sure pulleys on the top of eack spindle good to and everything is tight
a badly slipping vee belt will make a squeeling noise and somtimes will make the unit shudder
you will have to remove deck to replace bearing(s) , from experience replace mandrell/ spindle assys do both at same time because if one has gone the other wont be far behind - both do same milage and work and quite often if replace bearings only they dont go back in tight .
cheers hope it helps
pauly46
Posted on May 30, 2011
Riding mower makes noise and has a vibration when I engage mower blades and throws the belt off
Normally, this is caused by a bad / or worn out bearing in the blade spindle. The blade is attached to a shaft that goes thru the spindle housing, where the bearings are located, and then goes to the pulley that is driven by the blade drive belt. good luck
Jul 21, 2017 | Garden
As soon as blades are engaged, deck makes a high pitched metallic noise.
the brake lever spring may have broke or you may have a bad bearing. see if you can wiggle the blades up and down. if you can the bearings are bad. or you have hit something and bent the deck or blades
Jun 05, 2016 | Garden
My PB19542LT cranks and idles fine. But when you engage the blade it will not rev.
BlAde belt torque IS TOO HIGH It's reducing the engines running speed TO IDLE ALMOST check the blade brakes are releasing fully and the blade bearing are not tight or seem to move stiffly if the blade moved by hand ige ENIGINE OFF SPK LEAD TAKEN OFF PLUGS FOR SAFTEY AND IGNITION OFF TO AVOID ACCIDENTAL HAND CRANK ROUND START HALFWAY ENGAGE THE BLADE SYSTEM SO THE BRAKE SHOES RELEASE FROM THE PULLEYS AND THE DRIVE BELT IS LOSE NOT ENGADEGED FULY TURN THE BLADE AROUND BY HAND IF THECBLADEXOR PULLEY IS HARD TO TURN UNLESS ITS CLOGGEDUP BY GRASS DEPOSITS BUILT UP IN THE DECK OR BEARING HOUSINGS TO FIX IT WILL NEED DISASSEMBLING AND CLEANING OUT OF DEBRIS THEN PUTING BACK TOGETHER IF THE PULLEYS ECT ARE NOT CLOGGED UP THEN THE BEARINGS may need either lubricating with a race bearing grease compound or or if the blade is almost impossible to turn then the blade BEARINGS are worn out And WILL need REPLACING by mechanic the deck ajustment may also be to much and its over TIGHENING The drive BELTS slowing down the engine HOPE THIS HELP WITH THE DIAGNOSIS OF FAULT CHECK THE DRIVE SYSTEM FOR THE BLADES FULY
INCLUDINGVANYVTENTIONING PULLEYS ETC UNDER THE MAIN BODY OF THE MOWER INVOLDED WITH THE BLADE SYSTEM IF ANY PULLEY ENGAEGERSXSEEM TO BE STIFF OR SEEMS TIGHT WHEN THE BELT IS LOSSEND THE PULLY BEARINGS NEED CHECKING OR LUBRICATING ETC THE BELT COULD ALSO HAVE SHRUNK TOO SMALL IF THE MOWERS BEEN STANING STILL A LONG TIME IF THE BELTS HAS DEGRADED AND SHRUNK IT WILL NEED TO BE REPLACED
Jun 01, 2016 | Garden
Mtd engage blades it smokes and make noise
Have you physically moved each blade by hand (with the machine shut-off),spark plug disconnected to see if both or all of the cutting blades move freely if there is any binding you probably have a bad blade spindle bearing . If those move o.k. then you're going to want to check the pulleys on top of the deck, one of these which do not go to the blades may possibly have a bad bearing and is not moving freely causing the belt to be burning up.
Dec 03, 2012 | Garden
When I engage the blades, I smell and see blue smoke, so disengaged the blade
Its not the drive belt. You have a bearing or etc. out.
I just have problem. The spindle bearing was bad.
Oct 01, 2012 | John Deere 22HP VTwin 48" Riding Mower
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
Craftsman 42" Tractor Blade Problem
sounds like either the spindal bearings are shot or maybe the spindal shaft is bent. check for up and down slop at the blades. then turn blades towards each other and check that the heigth lines up. also chec the idler pully to make sure it is not slapping around.
Aug 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engage blades makes noises
Sounds like the bearings are going out in one or both of your blade spindles. With the belt off,(and engine, of course) engage the lever on the dash. That will release the blade brake so the blades will be free to turn. Spin each one by hand. It will be easy to tell if the bearings are bad.
Jun 06, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
363 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
