Question about Ovens
Do they still make Tappen Products? You don't se many around.
  • Ovens Master
  • 3,361 Answers
Yes.
Posted on May 29, 2011
Looking for owner manual.
type in the name and model number of the stove in your search engine and it should come up with some websites
example of what to type in your search engine
tappen model 678 manual
Mar 21, 2016 | Ovens
F! fault on Tappen range
I am assuming that by F! you meant F1. If this is the case it is a generic fault code meaning that the EOC (electronic oven control) is bad and needs to be replaced. It can be caused by any number of different things or by absolutely nothing at all. Sometimes these computer boards sense errors that don't actually exist. I would suggest turning power off to the unit for at least 2 minutes to perform a soft reset on the control. This will clear any error codes that the computer has stored and will be restarting from scratch. Sometimes this can be enough to solve the problem. If the error code comes back after the unit is powered on then you will need to replace the EOC to fix the unit.
Nov 15, 2012 | Tappan Ovens
How do I start the self cleaning? I hit clean and it does not start
On most self-cleaning ovens after you push the clean cycle button you have to tell it how long you want it to clean. Try pushing clean then pushing 3:00 for 3 hrs. If you don't have a number pad try pushing the clean pad several times and see if it cycles through clean levels like low, med or high. Then after you tell it how long to clean hit start. If you don't have a start button the oven should start cleaning after around 5 seconds. It will lock the door and begin the clean cycle. Also remember it takes around an hour for the oven to cool and unlock after the cycle is finished. Hope that helps.
Aug 29, 2011 | GE JKP45 Electric Double Oven
I need a baking element for the tappen oven model number 486847a. The stove serial number is VF41807648. Can you help
Go to www.ukwhitegoods.co.uk you will need the model number and serial number and place an enquiry. They will get back to you.
hope this is helpful
John
Jun 05, 2011 | Ovens
My 30 year old wall Tappen oven, the pitot is lit but no gas comes through to lite oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 07, 2011 | Tappan Ovens
Timer alarm volume is down
iam sorry to tel you there is no way of turning it up you would have to get a new timer
Paul http://www.apart4u.co.uk
Mar 04, 2010 | Ovens
Gas oven(tappen) with broiler draw. oven will not light, no pilot
if this is fairly new, there is a hot surface ignitor near the back of the burner in the bottom part of the oven. This can go bad. There is a connector that can be pulled apart where the ignitor meets the wiring harness. Ohm out the ignitor or have someone with a meter ohm it out. There should be resistance and not open. If open the ignitor should be replaced. If you have a broiling element, turn that on. If the broil element comes on then the ignitor is almost for sure the problem.
Nov 21, 2009 | Ovens
The pilot light works and gas in oven is on, but no gas ingition
bad thermal bulb, try moving the bulb into the flame more.
Jun 25, 2009 | Ovens
Ovens Logo
43 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
