Question about Neff K3965XO Side by Side Refrigerator
I have an american fridge freezer -the ice box stopped producing ice for couple of months then started to produce ice for a few days before breaking down again-the remainder of the fridge &freezer works ok-the temp.in the ice box is not cold-any ideas on what is wrong?
  • Neff Master
  • 3,361 Answers
The icemaker thermostat is going bad.
Replace the icemaker.
Posted on May 29, 2011
Testimonial: "thank you-do I need to replace the complete icemaker unit or just the thermostat?"
  • steve
    steve May 30, 2011
    It would be best to replace the complete icemaker.
I bought a hisense fridge a month ago, it was Ok when we connected just for couple of days, I turned the temperature up a bit so the freezer can be colder, but now
Hisense is a company that makes cheap budget end televisions. Sounds like the defrost timer may have failed. The cold is created at the rear of the freezer and cold air is vented to the fridge. Have it looked at under warranty.
Feb 02, 2017 | Frost Refrigerators
My American style fridge /freezer - Siemens KA62DS506B stopped producing Ice and water . The panel stopped being lit and there is a msg saying IWD Off
Your ice delivery water soleniod has failed, you can locate the solenoids in the rear lower of the fridge freezer unit where the pipes for water delivery goes in to the unit, locate the Ice delivery solenoid and replace it, easy test is to place a test cord on each solenoid and chech for operation under pressure. Russ
Apr 25, 2012 | Refrigerators
My freezer doesn't keep ice cream frozen more than a couple of hours. Other foods are frozen, but some slightly 'soft' frozen. Up until a couple of weeks ago it would produce ice cubes regularly. Now if I...
YOUR DEFROST TIMER MAY BE BAD OR THE HEATERS ARE BAD. WHAT HAPPENS IS THE EVAPORATOR IS FROZE OVER WITH ICE AND CAN'T TRANSFER THE COLD . UNPLUG THE FRIDGE FOR A FEW HOURS (HAVE RAGS AND MOP READY) AND IT WILL WORK AGAIN TEMPORALLY . THE LESS YOU OPEN THE DOORS THE LONGER IT WILL LAST.. BACK IN THE DAY IT WAS CALLED DEFROSTING THE FRIDGE AND WAS DONE ONCE A MONTH OR SO
Jan 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Jul 08, 2009 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Icemaker not producing ice
Most automatic ice makers have a lever (looks like a piece of wire) that is prevented from being in the down position when the bin is full. This stops the ice maker from producing ice when not needed. The lever can also be lifted manually to a locked up position which turns the ice maker off as well. If the lever is in the up position, simply press down on it, it should release and return to the down position. Once down, the ice maker will begin producing ice again (the unit will have to complete its cycle before you see any ice, normally a couple hours or less). Hope this helps.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Frbb2vaf20 American fridge freezer - Not holding temperature
Get a hold of who ever you purchased it from. It should be under warranty and they should get it working for you.
Jun 22, 2017 | Refrigerators
Sub zero fridge
water filter maybe too dirty
Jul 05, 2008 | Sub-Zero Refrigerators
Neff K3965XO Side by Side Refrigerator Logo
398 people viewed this question
Top Neff Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
