Question about Pentair Minimax CH Heater
Heater fails to ignite after replacing; gas valve, electronic thermostat board, on/off switch, pilot millivolt. on a minimax ch 200 Pool heater.
  • rloveland Jun 01, 2011
    I replaced the pilot valve and this solved the problem
    thanks
  • 927 Answers
I have a pool heater, let me try to do this from memory.
For a gas heater to allow an ignition several things must occur and be proven.
There is a water pressure switch or flow switch to ensure water that will take the heat away from the heat exchanger is there in adequate flow. Find this switch and ensure that it is closing.
Next, a forced air fan starts. There is a switch that closed if air flow is adequate for the amount of gas in the flame. Is that switch closing?
The thermostat must be set higher than the incoming water temperature, is that circuit closed?
At this point, the electronic igniter sparks on my heater. Do you have a standing pilot light?
Next, the gas valve opens. Is the gas valve getting voltage?
If so, once the flame ignites, there is a thermocouple that must sense high flame temperature to allow the gas valve to stay open to heat the water.
There may be more and this may not be all for your heater, but if you have a multimeter, these are some things you can test.
Gary - let me know how you do.
Posted on May 30, 2011
Pilot does not light
these pilots are pesky they clog with rust and junk replace the unit
Jun 28, 2014 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pilot stays lit but heater will not fire up
so it is a millivolt .and the answer is yes there is a water pressure switch inside the heater, but also there is a internal flow control valve in right side of the heater,check by removing the 2 bolts, and look inside if there sand left ,by brucken laterals inside filter, also check for gas pressure ,the pilot stay lit ?
Jun 15, 2013 | Pentair Minimax Ch 250,000 Btu Natural Gas...
My pool heater Pentair ch minimax 150m has no voltage to gas valve. The pilot is on .
ok is millivolt heater need to check all the safety circuit are getting power ,also check for clean filter ? is the water pressure switch inside the heater is closed ? did u check if the pilot generator is generating more the 600MV ? also check for any loose wire connection ,a 9 volt battery generated more voltage that u pilot generator
Jun 08, 2013 | Pool & Spa
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Propane Millivolt Ignition Heaters error E05 what is it?
If you are firing, and then going off and getting an E05, your igniter is to blame. It may be glowing but it's getting weak. The diagnostic goes further but that is usually the fix.. With inactivity, the igniter is always to blame. You really need to fire it off weekly to make it reliable and make sure that your heater is serviced at least one time a year to keep all the internal components operating as designed.
  • PILOT ASSY LP MV CH150 IID
  • Manufacturer: PENTAIR WATER POOL AND SPA INC
  • Manufacturer Part #: 471291
  • Description: Propane pilot assembly for heaters with millivolt ignition.
  • Retail Cost: Approximately $65.00
Dec 08, 2010 | Pentair Minimax Ch 200,000 Btu Propane...
Do not know how to start pilot light
There should be instructions on the inside of the heater access door. Make sure you are comfortable working with gas heaters. Make sure the shutoff valve supplying gas to the heater is on. Turn the gas valve to "pilot", press and hold it while attempting to light the pilot. Once the pilot is lit, continue holding the gas valve knob down for about 30 seconds. The pilot should stay lit once you release the knob. If the pilot stay lit, turn the gas valve to "on". Replace the heater access door and make sure you have proper water flow and attempt to light the heater. If it will not light, or the pilot will not stay on, you will probably have to replace the pilot generator. It provides voltage to run the heater and after time it wears out and produces less and less voltage. A millivolt heater runs on less than one volt so any power loss can be a problem. If you are able, test the pilot generator with a multimeter to see if you are getting at least 500mv when the pilot is on. If not, you should replace the pilot generator or even the entire pilot assembly. Hope this helps...
Sep 27, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
The pilot come on but not the burners
is t gas valve on is t tem on high ? 24 v at t brown wire at t gas valve replace gas valve if not replace ignitor
Jul 03, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
New ignitor..still won't light
Clean out the pilot assemby or replace it. It is probably blocked by rust and/or spiders and is not letting enough gas (if any) through.
Jun 18, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Minimax CH Heater Logo
216 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
