Question about AOC 912SW-1 Monitor
I am trying to connect and use my monitor as a tv moniter how do i do that
    Sergeant:
  • 247 Answers
The only way possible i believe that that model aoc. is to use what we call a break out cable, this is a cable used to attach vga on one end and component or rca on the other end, the only issue is that the aoc 912sw has no audio outputs so what ever source you wanted to use to push the image on your tv must also have audio and external speakers must be used. here is a link to a breakout cable break out
Posted on May 29, 2011
I WANT TO USE MY DESKTOP TO PLAY FILMS ON MY TV . DONE THE CONNECTIONS AND GOT THE RIGHT SCREEN WHEN THE COMPUTER STARTED UP THEN IT WENT BLANK SO I CHANGED THE RESERLUTIONS ON A MONITER SCREEN THEN...
What you should try at this point is shut everything down, Unplug your desktop, hook it back up to tour moniter and boot. If you now get a picture, go to your device manger and click on display adaptors. If you have more than one selection. choose your monitor. Let me know if this works.
Mar 11, 2011 | Computers & Internet
Computer see the monitor
if the moniter is an Acer brand, the logo could just be the moniters sceensaver and not the actual computer. If you have tried other computers and connections that you know to be working it would seem to place the fault with the moniter. try googling the brand and model of the moniter to see if there are any known faults and fixes.
Dec 11, 2009 | Computers & Internet
When I hook up my moniter it does not work like other moniters.
ok sounds like you have a broken pin on your cable if you look in the end of the cable plug the part thet goes into the box but also check both ends if they are there
failing that take monitor to roof and heave ho away it goes
Jul 25, 2009 | Compaq P 1220 22" CRT Monitor
Getting sound through mogen lcd tv
Yes, you need a 3.5mm male mini stereo to male mini-stereo cable. Plug into small hole in monitor to lime green port of computer352d_2.jpg
Jul 06, 2009 | Computers & Internet
No power to moniter
This kind of problem needs an isolation. Please try the steps below:
1. Check the physical connection and make sure that the power cable is properly seated to the monitor.
2. Connect the monitor into different power outlet.
3. Try using different power cable.
Otherwise, you need to bring your monitor to the repair shop if none of the steps help.
Have a great day!
May 09, 2009 | HP L1702 17" LCD Monitor
I have a compaq laptop and a samsung lcd tv i tryed to connect using a vga and after startup screen on tv goes black but moniter on the laptop works fine any help would be appreciated
You would have to allow the laptop to use the tv as a external monitor. simply right click on your desktop click properties in their just have a look around and it will show 2 monitors allow the tv as one
Hope this helped
-Ryan
-Please Vote if this helped.
Feb 18, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Can´t connect my laptop to tv monitor
Try lowering your screen resolution on the laptop first. (Right click on desktop > properties > settings tab > and move the bar to the left - try the lowest setting to start with
Jan 22, 2009 | Acer Aspire 4720 Notebook
Trying to use my tv as a moniter
If you still have the pc monitor pluged and want to use the tv as an exetended desktop
you have to activate the second monitor in the - control panel - Display - settings
Sep 18, 2008 | Computers & Internet
Screen turns on and odd
If the TV part works normal then you are probably trying to use a resolution and or refresh rate the monitor cannot handle. You want to be on 1024x768 max and 60hz refresh. You can try starting the computer in safe mode to test.
Jul 06, 2008 | Mag Innovision M572TVs LCD Television
Connect Playstation 2 to computer monitor
try going to your local radioshack and asking for a cable to do it. Tell them it needs to be "double male" infering that the piece sticks into another part instead of bieng stuck into. Then tell them one end needs to be "RCA cables" (the red white and yellow ones) and the other end needs to be a computer moniter cable. There are several types of moniter cables you can use, look in the back of your moniter to see what you have. There should be writing that says any 1 of the following "s video in", "dv in" "video in" etc. ask the radioshack man to get the non RCA side of the cable to have one of these on it. If you need to, it helps to take a picture of the back of the moniter where all the input plugs are, and show it to the radio shack man, he can probably help decide which cable to use. Once you buy the cable, plug the red yellow and white side into the red yellow and white holes respectively on the PS2, and the moniter cable into the moniter. Turn on the moniter and the PS2 and... Voila. PS You may need to take out the cable connecting the moniter to the PC to put in the new radioshck cable. I hope this works for you-BCA
Aug 26, 2007 | Sony PlayStation 2 (PS2) Console
AOC 912SW-1  Monitor Logo
159 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
