Question about Garden
Need to find Delta 12 1/2 " Planer Instruction Manual # TP305
  • 5,384 Answers
Porter-Cable/Delta has the manual at their Servicenet support site: http://servicenet.deltaportercable.com/Products/Detail?productNumber=TP305 . The link is on the right under downloads (the last item in the list).
I hope this helps.
Posted on May 29, 2011
Sniping
You get sniping with all planers and it will always be the length from the cutter head to the second feed roller. Until the board goes under the second roller it is almost impossible to feed it through and not get some sniping. The same applies to the outfeed side also. Better made (more expensive) planers, table extensions and holding up on the end of the board until the other end is under the second feed roller will reduce sniping somewhat but you'll always have some sniping.
Mar 03, 2013 | Delta TP305 12 - 1/2" Portable Planer
Why does my TP305 takes off more material at the beginning and at the end of the board than it does in the middle? It is a considerable amount. I've cleaned and tightened everything I can.
This is called snipe and it is a common problem. There are two feed rollers, one before and one after the cutter. When one of them drops off the board, the cutter drops down a little. You can minimize this by taking very light cuts, even making your final cut a second pass without lowering the cutter at all. You can also use a scrap piece of wood immediately preceding and following your good piece (it has to be long enough) And of course you can start with your good piece over-length. Good luck.
Jan 01, 2013 | Delta TP305 12 - 1/2" Portable Planer
My tp305 removes more wood on the left than on the right. There does'nt seem to be anmy way to adjust this, is there?
These portable planers have a not-negligible amount of flex to them, and you will probably remove a bit of wood even if you run the board through a second time on the same side. But try this to determine if you would want to try to reset the blade height---- run two narrow pieces simultaneously on the left and right. Check the thickness before and after with calipers or something precise. Then switch the two boards and run them again without changing the setting. If it is only cutting on one side, and the thickness was significantly different before the second run, then you might want to adjust the blades in the cutter-head.
Good luck.
Oct 01, 2012 | Delta TP305 12 - 1/2" Portable Planer
Do you have a owners manual for a Delta planer tp305
go to Dewaltservicenet.com and you can download the owners manual for this tool, it is 48 pages long. Let me know if you need more help and if I have answered your question would you please vote accordingly, thanks
Mar 15, 2011 | Delta TP305 12 - 1/2" Portable Planer
Why do i get saw dust build up uder my blade and end up bending the blade and hold down bar
U need to hook it to a strong shop vac. There is an adapter for a vacuum hose. Joe
Mar 20, 2010 | Delta TP305 12 - 1/2" Portable Planer
How do you replace the belt?
go to Dewaltservicenet.com and type in your model number and you will find a detailed breakdown for this tool. Let me know if you need more assistance
Dec 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
Need an user/owner manual for a Delta Shopmaster 12'' Portable Planer Model #TP300
Heres your Manual:
http://powertool.manualsonline.com/manuals/mfg/delta/tp300.html
Oct 15, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Belt on delta planer
I went to Dewaltservicenet.com and looked at a parts explosion and also the instruction manual for this tool. The manual doesn't say anything about how to do it, BUT the explosion is good quality and should guide you thru replacement. Please let me know if I can help further and if I answered your question would you please rate it accordingly Thank you.
May 15, 2009 | Delta TP305 12 - 1/2" Portable Planer
How to change blades in planer
Go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom. Select the model number I looked at a type 2 and click on it on the next page find instruction manual on the left hand side and I did have to click 2 times before it brought it up but it is there I just read part of it. The manual is about 17 pages long but the page you need is 11. Let me know if there are any problems please and if I have helped in anyway would you please rate the response accordingly.
May 14, 2009 | Delta 22 - 547 12" Steel Knife Set for 22...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
