Question about Polaris 800 Twin Sportsman Ride on Toy
How do you change out a relay board, pinon assembly and circuit board adapter
  • theflavor32 May 30, 2011
    sorry i forgot to mention it is on a peg perego 800 twin
    Genius:
  • Polaris Master
  • 1,508 Answers
Wrong forum
Posted on May 23, 2012
Why my tail lights don't work on my chevy monte carlo ss
fuse, relay, bulbs, and on some models, the bulbs attack to a circuit board on the inside of the tail light assembly. Chevrolet is good about producing faulty tail light circuit boards.
Dec 28, 2016 | Cars & Trucks
How to replace bearing in a 1991 chevy 1500 4x4 rear axel at driveshaft?
To replace pinon bearing you need to pull wheels and the brake drums off next pull cover off the back of the rear end (make sure you have a drain pan under rear end) next turn dive shaft till you see a small bolt remove bolt pull center pin out push axle in pull c clips out pull axels out remove four bolts holding ring and spider gears remove gears assembly next remove drive shaft remove bolt from pinon push pinon in remove seal and bearing
Jun 27, 2011 | 1991 Chevrolet K1500
Have MMV4205BAW18 with a main control relay problem. I am told that I can replace this relay myself provided I can find the part. The part number is w10181450. This is a manufacturers part number. Can...
W10181450 is the part number of the whole circuit board, not just the relay.
That board runs $130.74 and you can order it from the Pros here.
The attached photo shows where the two cook relays (RY01 high power and RY02 low power) are on your circuit board.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can contact us via our site with the numbers on your relay, and we may have one or more available.
Whirlpool / Maytag does not make relays available, one has to get them from third-party suppliers by the relay manufacturer's number.
Or we can repair your control panel assembly for you for $39.95. Details are here.
Let us know if we can help further.
Dec 31, 2010 | Maytag MMV4205 Microwave Oven
GE PSS25MGMCAA refrigerator - Bad circuit board??
You need to change the board . Part number WR55X10656 . The board relay , cannot be changed . Power surges , dirty condensor coils , and usage , are the most common causes , for board failure .
Sep 23, 2009 | GE Refrigerators
WHERE IS THE FAN MOTOR RELAY
usually mounted on the fan housing, with the relay assembly sticking inside the fan housing. Locate the fan housing in the engine compartment and look for a plug and board. Unplug and unscrew the board and lift the relay out of the fan housing. Usually looks like a couple of coils on a circuit board.
Replace and re assemble in reverse order.
Aug 05, 2009 | 1994 Mazda B-Series
Blower fan stays running. Fan relay attached to small circuit board (coil tabs [timer?]). Capacitor on small circuit board had ''fallen out'' of ic board. Tried to get replacement board, and was sold...
If fan runs on 220 you have one constant 110 that always goes to the motor. The other 110 goes through something that will turn it off and on. This being the relay, just like a light switch. This 110 will land on the "N O" (normally open) set of contacts. "Open" meaning the voltage can't pass through. When the relay gets energized the contacts close. This completes the circuit, the motor gets the 220 it needs and it runs. On the relay coil (how it gets it's energy) you need a low voltage common and you need the "G" wire from the tstat. Likely green in color, this is your indoor blower low voltage wire. When the tstat calls for fan, cool or heat, the relay energizes, closes the contacts, fan runs. Good Luck!!
May 16, 2017 | Carrier Heating & Cooling
4ws light will not go out have changed computer but still on
Probably both computers are faulty. Old age and vibrations crack the relay soldered joints inside the comuter (behind rear seat). Sometime invisible cracks, so resolder all relay connections to the board. Disconnect battery; remove rear seat (LHS - two pull-clips under front of seat)) and seat back; unbolt wires etc, unbolt steelwork & computer; open computer case; circuit board with copper strips to it has two black boxes (relays; remove this circuit board & resolder relay-to-circuit board joints. Check other circuit board for bulging capacitors & replace as required with same values. Probably cure all ills - cured all mine!
Feb 28, 2009 | 1994 Honda Prelude
Main relay assembly for 1995 Honda Accord
the relay cover slides off very easily so you can expose the circuit board take your pgmfi relay apart and you will see two small relays on the board look at the contacts for the relays to see if theyre burnt then turn the board over and look at the sauder joints at least one of these will probably be burnt or not enough sauder will be ther to make a good connection.Look real carefully at these i use a magnifying glass my self because i have seen numerous times where the sauder will have a small crack (like a ring or circle) around it causing a poor connection these are the most common problem with these relays (almost the only problems) i have seen in the past six years that i have worked at my local honda dealer
Dec 12, 2008 | 1995 Honda Accord
Polaris 800 Twin Sportsman Ride on Toy Logo
67 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
